Turbo_punkn
Are there and boost gauges available yet for the 2.0?
Are you talking about the gauge pod? Any gauge with an appropriate boost range will work.Are there and boost gauges available yet for the 2.0?
Anyone know where you would tap on for it? I new to the turbo stuff. I figured you could get any guage that read the psi range for our turbosAre you talking about the gauge pod? Any gauge with an appropriate boost range will work.
Nope.I was wondering about a boost gauge. Is there anything in the Infotainment or Off Road Pages?
Mine makes 24.x psi initially but tapers down to 21-22 in higher gears. Runs a lot more boost than I expected.Does anyone know how much boost the 2.0T makes?
24 PSI??? Are you sure?Mine makes 24.x psi initially but tapers down to 21-22 in higher gears. Runs a lot more boost than I expected.
Typical measure of a turbo is in pressure.Volume matters. PSI by itself is meaningless.
Absolutely. Reality is efficiency is really key. Larger turbos will have a more dense charge as the air isn't as heated. Lag is an obvious downside. The key is finding the right efficiency utilizing the smallest turbo possible to achieve the desired air charge.Typical measure of a turbo is in pressure.
25 might be supercharged. Turbos are a bit less.I can't believe it is making 25 PSI, no way.
A bit less? Even that article says 6-8 PSI is typical.25 might be supercharged. Turbos are a bit less.
https://auto.howstuffworks.com/turbo1.htm
