JasonInDLH
First I’ve heard of this portal axle stuff (saw it in January ‘23 Four Wheeler Magazine), but apparently they’ve been around for decades.
Sounds like a winner to lift (3.9”), re-gear(4.10 OEM gears will be like having 5.00 gears and 3.73 OEM gears will be like 4.55) and upsize your brake rotors all in one package. It lifts the axle, thereby giving you much better ground clearance at the differential (as opposed to a suspension lift and bigger tires) and room/ability to run 37” tires (40” if you’re willing to do some trimming).
With 40” tires aired down to 15psi on Currie 60 axle housings you’ll see 16.25” of ground clearance and would be able to drive over one of those 5 gallon Home Depot buckets. Not bad!
A couple downsides I can think of is:
1. Your articulation will be hampered since you’d be using your stock suspension.
2. The 8 ounces of 250W gear oil in these things (multiplied by four wheels) need to be changed every 10,000 miles. I guess this isn’t too bad, but just some added work.
3. I don’t know how much these things cost, but I’ll wager they’re expensive.
Here’s their website:
https://motorsports.74weld.com/jeep...zTqicTJKDSQGLBLi3vhzCV5rSU1SQNZRoCcQIQAvD_BwE
