DocTwinkie
Just an update for folks doing installs where you have to loosen body bolts. There are many horror stories on the forum of broken bolts due to the loctite. I’d also say due to over torquing at the factory (supposed to be 80ft-lbs.
I used the mini ductor 2 induction bolt heater. Loctite need 550 degrees to melt.
Run the bolt heater about 30sec until just starting to glow then give 30sec off. I repeated this about 4x per bolt (6 on the front which have red loctite). this allowed the heat to conduct up the bolt.
I used a breaker bar instead of an impact wrench. I had no creaking or popping. Just a smooth loosening. Wear leather gloves since the bolt will be hot and that heat will go into your socket and bar.
I repeated the process to tighten them as the loctite will reset and torque to 80ft-lbs. The loctite will reset once cooled.
Lots of folks just break them free which is fine most of the time but it’s a gamble. A torch can be used if that’s your jam but it’s outside my comfort level. The bolt heater will help later for any rusted or seized bolts on later installs.
Hope this helps folks.
