Sold: Georgia BNIB FOX Factory Race Series 2.0 ATS Steering Stabilizer - 983-02-148 $400
MichaelAnthony
Michael
Aliquippa, PA
2019 Wrangler Rubicon JLUR, 97 Centurion Dually 7.3, 97 Classy Chassis Dually 7.3, 2016 Ultra Classic CVO
PRODUCT OVERVIEW
With conventional steering stabilizers, turning in one direction creates an increase in pressure inside the stabilizer as the shaft occupies more volume in the body and displaces the oil. The repercussion is a push or pull steering force felt by the driver as the stabilizer attempts to return to its neutral state. To overcome this unidirectional force, dual opposing stabilizers are often used, but this requires additional mounting hardware and space. The Factory Race Series 2.0 Stabilizer ATS utilizes an Adjustable Through Shaft (ATS) architecture that eliminates shaft fluid displacement throughout the stabilizer's entire travel in both directions. The external piggyback reservoir provides additional fluid capacity and utilizes an Internal Floating Piston (IFP) to separate the fluid from the nitrogen gas charge to eliminate cavitation. For increased control that can be tailored to any driving style and setup, an external adjuster provides 24 clicks of adjustment to fine tune the feel. The result is highly customizable and consistent damping of unwanted steering feedback in a single, bolt-on stabilizer.
FOX | Part Number: FOX983-02-148
Fitment: Direct Fit
TECHNICAL DETAILS
20-Current Gladiator JT
18-Current Wrangler JL, 2 & 4 Door
Body: 2.0 inch impact extruded and CNC machined 6061-T6 clear anodized aluminum body resists rust over time
Body plating: Hard-anodized for a durable finish
Reservoir: External reservoir design separates shock oil from the high-pressure nitrogen
Components: Black-anodized, CNC-machined 6061-T6 billet aluminum
Shaft: 5/8 inch hard chrome plated heat-treated alloy steel
Piston: Race-developed high-flow piston design
Seals: Redundant sealing pack system main seal, wiper seal, scraper seal
Oil: JM92 Advanced Suspension Fluid for improved performance at variable temperatures
Bushings: Quiet nitrile rubber allows for increased suspension articulation
Adjustments: Adjuster - 24 clicks of adjustability
Travel (IN): 8.10
Compressed (IN): 15.10
Extended (IN): 23.20:Top mount: Eyelet
Bottom Mount: Axle mount
MichaelAnthony
MichaelAnthony
Michael
Aliquippa, PA
Will include shipping.....
MichaelAnthony
MichaelAnthony
Michael
Aliquippa, PA
For the price I will include the shipping.
MichaelAnthony
MichaelAnthony
Michael
Aliquippa, PA
This is brand new never used still in the box. I bought this here and decided to go a different direction. So it is back up for sale. Currently working in Charleston WV traveling back and fourth north of Pittsburgh.
MichaelAnthony
MichaelAnthony
Michael
Aliquippa, PA
Currently working in Charleston, WV and driving up to Pittsburgh on the weekends...
Izzo93
Nathan
Pittsburgh, PA
'18 Jeep JLUS, '18 Ram 1500 5.7, '10 HD CVO FLHXSE
MidStream Gas Plant Operator 2
300 and I’ll meet you. I live 15 mins north of Pittsburgh in Evans City
Clayton Offroad
