Blind Spot Monitoring Unavailable after doors off
Stuweeks
Stuart
Nashville, TN
2018 JLU Rubicon
I’ve had my JL for over a year and had my doors off numerous times. All the doors are plugged in (triple checked, unplugged and plugged back in) and it doesn't recognize the doors are back on. Radio doesn’t turn off when I open my doors or anything, plus I get the Blind Spot error mentioned in the title. Anyone else having this issue?
TA1ton
Travis
Tyler, TX
2018 Jeep Wrangler JLU Sport S
Civil Engineer
@Stuweeks; check the pins in the plugs...one could be bent...seems like I remember somebody else having a similar problem and it was a bent pin. Good luck! :like::jk:
Kluk Ztopolovky
Kluk
Toronto
Wrangler JL Sport 2dr Sting Gray manual
I wouldn't worry about it. Just look around your surroundings more and enjoy the trip.
multicam
Tanner
Mojave Desert
2018 4Runner, 2019 JLR
This is almost certainly it. I had bent pins in my door harness that caused the dome light to not turn on when I opened the door. Dealer fixed it under warranty because I had no idea what was causing the issue. This is my first jeep with electronics in the door
chris4prez
Tampa
'20 JLUR
I've had similar issue with bent pins in the door connector causing the passenger mirror from being able to work. And this was after my first time taking door on and off. It's crazy that they used such tiny pins susceptible to bending.
multicam
Tanner
Mojave Desert
Funny you mention that; since my last post in July I have fixed all my door wiring harness related issues except the one you’re describing.
As I mentioned in July the first issue was causing the jeep to not recognize the doors opening (made most obvious by the dome lights not coming on). Took it to the dealer; they explained that it was the door wiring harness. A few months later I got the dreaded ESS disabled error. I straightened the pins myself; error went away. More recently I found that I couldn’t adjust the passenger mirror. Since it is already in the right spot I haven’t bothered to try and fix it.
This makes me miss the days of having no wiring harness between the doors and the jeep. While it’s obvious that jeep should have designed more durable connections, I can’t help but think that no matter how robust they would eventually succumb to years of being connected and disconnected week after week.
Mac Haik CDJR Georgetown
