DanFelix
- Dec 22, 2018
- Riverside, CA
- 2018 Wrangler JL Sport S
I am trying to install a second Blind Spot Indicator Lamp for Driver and Passenger side. The attached wiring diagram shows a Lamp-Blind Spot Indicator-Driver (the 'Driver' referenced is not a reference to the Left side of the Jeep but to the bulb.) For the Driver (left side) it is a Black/Brown wire into the bulb and a Black ground wire out of the bulb.
Should my lamp be in series to one of these wires or parallel to both wires to the bulb in the Driver (left side) Outside Mirror wiring? My actual wiring will not be at the mirror wires but 'upstream' of them, Green and Black, respectively. Will either arrangement trigger the turn signal lamp? I have attached the Blind Spot Monitoring System Wiring diagram to help.
I need a second set of eyes on the diagram to help me understand it. Thanks.
