calemasters
- Allen
- Sep 14, 2020
- Springfield, Mo.
- 2021 Rubicon Unlimited, & Escalade
- Occupation
- Retired Mechanical Engineer
I installed a BlackVue DR590X dash cam. Since the camera came with both the 12v plug power outlet cable and a hardwire cable, I did the hard wire cable installation. The camera has two (2) power inputs, one is BAT which is hot at all times, and the other ACC input is hot in ACC / Run. The 3rd connection is ground.
The camera came with a Blackvue 32GB micro SD card, but the camera can handle up to a 256GB card. I purchased a SanDisk 256GB micro SD card from Amazon for $37.99. When I installed the SanDisk card into the camera, the camera could not read the card. So I removed the card and replaced it with the supplied Blackvue 32GB card and the card did format in the camera and functioned properly. I read in the Blackvue quick start guide that only the Blackvue micro SD card will work properly. This turned out not to be true. On the Blackvue website the Blackvue brand 256GB micro SD card has a new lower price of only $190.98. I really prefer Amazon's price. I tried formatting the SanDisk 256GB micro SD card from Amazon in my computer using FAT32. Then I installed the SanDisk 256GB micro SD card into the camera and it works perfectly.
I connected the "BAT" lead on the supplied hardwire kit to the Auxiliary #4 switch circuit Blue/Pink wire under the right side of the I.P. The Auxiliary #4 switch circuit has been programmed to latch and connect to “Battery Power” and is “Hot at All Times” when the switch is closed.
I connected the ACC lead on the supplied hardwire kit to the "accessory" Orange/Pink wire under the right side of the I.P. This circuit is “Hot in ACC/Run”.
By connecting the camera in this manner, I can turn off the Auxiliary #4 switch if I want to power off the camera while the Jeep is parked.
I have the Blackvue G-1EU GPS receiver on order and will install when it arrives. It provides speed and location data on the video recordings.
