Bike Rack Options??
pianomankd
Kyle
Cape Cod
youtube.com
2021 JL - Sting Gray
very nice, thanks, I did not think that one would fit; so it must just nicely straddle that 3rd brake light and doesn't interfere with the rear wiper? do you know if there is an option to mount those bottom straps meant for under the bumper to the bottom of the spare instead?
I’m not sure how you’d mount the bottom straps to the tire. There are two metal lips on the bottoms of the straps for the bottom of the door that you use. It’s nicely against the brake lite and doesn’t block it. Really well built for a “spare tire mount”. Definitely the best I’ve seen so far until more official ones start rolling out...
trble
Brett
Washington
2018 Wrangler JL Rubicon
Disabled Vet
RichieRugs
Richie
LA
JL Sport S
Do they offer a locking system of some sort? The rack to the car, and the bike to the rack.
jassem99
Basil
Toronto
Jeep JLUR
If the active safety group is included with the blind spot monitoring then no, I opted against it.
I loosened the mount of the 3rd brake light, then tightened it again after installing the bike rack. They touch each other, though, but not in a way that would bend or force-back the brake light mount.
Here is Colorado the 3rd light is not a requirement and I may decide to take it off altogether.
One more Hollywood SR1 rack on JLU. No problems installing the rack after loosening the 3rd brake light with T25 torx as above. Had to add some protection for wheel on bottom of rack U-section to avoid scratching wheel. Ideally black split rubber donuts would do the job with 1" inner diameter.
Jeep Wrangler JL Bike Rack Options?? JLU_SR1
Blind spot monitoring unaffected with or without bike on rack. Parksense automatically turns off with bike on since it beeps continuously due to tire proximity to sensor. Camera view unaffected when no bike on rack.
No complaints for price of SR1, but would probably not add a second bike unless hinge reinforcement installed.
RichieRugs
Richie
LA
JL Sport S
I drive JLUR. Need a rack that will allow access to the trunk, clears the Rubicon spare, and has built in locks. Kuat NV 2.0, 1 upUSA, Yakima full swing? Thoughts? My head is spinning trying to make a decision.
Thanks,
AUMacman
Canton, GA
Jeep Wrangler JLUR
Well I ordered the Thule T2 Pro Xt hitch mount bike rack and the 1up 7.5" hitch extender. I'll let y'all know how it works out once the Jeep and the rack arrive later this week/ early next week. :like:
Any update on how this is working out?
Tunesoul
Kirk
1999 Jeep Wrangler Sport, 2012 Subaru Outback, 2018 Ocean Blue JLUR
Owner of a Mobile Auto Paint Touch Up Co.
So far I really like this setup. The 1up hitch extender has a threaded pin that let's you tighten it so that there is no play, it is rock solid and it also has a locking mechanism. I didn't get a drop down so you can only open the gate about 1 foot before the spare tire touches the rack, but that's totally enough to grab your riding gear out of the cargo area. The backup camera still has a great view between the two wheels and below the bottom bracket when you position the crank arm out of the way. I'll be making a video on this hitch rack set up for my youtube channel next week. I'll post a link here once I upload the video. Here's some photos of the rack on my JLUR. Hope this helps! :like:
Jeep Wrangler JL Bike Rack Options?? 83A362EE-E629-4B05-BEEA-BA58B57B78A3
Jeep Wrangler JL Bike Rack Options?? D21F4095-9900-4BC5-AD70-0B0DD1C7E5A6
Jeep Wrangler JL Bike Rack Options?? 22619F9D-7B1C-4D43-AA4F-5F514D1929E9
Jeep Wrangler JL Bike Rack Options?? 4A83BFFA-97BF-44F1-8A8D-CE966CF773B2
Jeep Wrangler JL Bike Rack Options?? BB67E459-7F2A-4D93-B0FA-ACA05460988F
crash13
Toronto
2018 JL Rubicon
Looks good. Where did you pick it up? and my bikes are less than 17lbs each so not really worried about the weight ;)
jayz235
Jay
Minneapolis
Wrangler JLU Sahara
Thanks,
Richie - here's my solution that matches all of your criteria; Rubi wheels on my Sahara are cleared with full access to trunk, locks included:
Kuat Pivot & NV Base. There is still an issue with the handle fitting fully locked, but Kuat is releasing a fix for that so I'm not worried. Pics with my street cruiser as well as some rear camera shots with bike loaded and rack in it's upright position.
BTW, this rack is SOLID. Hardly budges at all when everything is tightened down. I'm beyond impressed! And the finish looks really good IMO.
FYI I expressed this to Kuat and they assured me that a fix for the handle is coming soon. Their customer support has been outstanding. They've sent me a pack of lock cores for free so my locks all match and well as offered me discounts on future purchases.
Saejin
Gene
Colorado Springs
JLUR - Firecracker Red
I only need to carry one bike and I prefer to carry it inside the Jeep. Here’s what I did and when the trail rail system comes out I’ll be able to build a better mount.
Jeep Wrangler JL Bike Rack Options?? B8F924CD-8122-4430-998A-65E8CCE9435B
Jeep Wrangler JL Bike Rack Options?? 63FA0B0A-3FA4-4C6E-8CA7-8DE11E1BE073
Jeep Wrangler JL Bike Rack Options?? 50CBF7DA-D263-4A62-9E99-F82B443C7BCA
Jeep Wrangler JL Bike Rack Options?? 5988354C-2E3C-4135-A9F2-07863E7EC531
Jeepnick
Nick
Pittsburgh
Tacoma pro
Spoke with the kuat rep at dirtfest this weekend
They put me on the list for the updated latch that will work with a rear mounted spare tire
Said 30 days out
Jeepnick
Nick
Pittsburgh
Tacoma pro
Although I have some desire to switch from my kuat setup to 1up since they offer a cargo carrier that also holds 2 bikes
Not sure if I can let go of the pivot option though
KDB
WI
2018 2 Door JLR
I need/want to carry two bikes as well and often times and in the back country on some rough roads so narrowed my choices down to 1UP and ISI. I've been in discussions (taking measurements and all to ensure best fit of their modular system) with ISI and hope to purchase a rack from them this week. The ISI is not too much more than 1UP but will lay down to allow for full access of the tail gate, even with bikes loaded.
http://www.isi-carriers.com/products.html
Jeepnick
Nick
Pittsburgh
Tacoma pro
That’s really cool
This kinda excites me though
Jeep Wrangler JL Bike Rack Options?? A37EA0FA-50A2-46C4-B079-14D47D6EBA7E
