JL18
- Tom
- Feb 24, 2019
- Birmingham, AL
- 2018 Wrangler JLU Sahara
I agonized over how best to make my Sahara Unlimited JL a little tougher looking without getting too crazy. I was going to go with aftermarket wheels, but decided not to because I didn’t like the offset choices and didn't want to have the wheels sticking outside of the factory fenders too far. I wanted them to just barely stick out. I looked at a lot of threads and did a ton of looking around before I did this. I think this will answer a lot of the same questions I had.
- I stuck with my original factory wheels.
- Went with Nitto Ridge Grapplers 295/70/R18. This is a 34.2” x 11.6” tire. As far as I know, this is the largest I could fit on my factory 7.5” wide wheels. Per Nitto recommended wheel widths.
- Added 1.25” aluminum, hub centric, wheel spacers, so the tires wouldn’t rub. Got them from Wheel Adapters USA.
- Went with a Daystar 2” spacer lift. I loved that this kit came with front lower control arms to keep the caster within spec. After install my caster is 5.5 degrees. I also wanted to maintain close to the factory gap between the fender and tire.
- Waiting on my spare tire relocation kit....
Very happy with the result, so far. The ride is still great, maybe slightly more harsh over pot holes and large bumps due to the E load rating of the tires. Road noise slightly higher than the factory tires, but still quiet. Definitely not annoying. Handling is still great. Very happy so far. Check out the pics, before and after. Hope this helps someone with their decision.
