- Andy
- Nov 19, 2019
- SanFrancisco
- JL Wrangler
- Banned
@BestopTeam
I've decided to try to leave the Bestop Sunrider on through winter months rather than replace it with the Freedom Panels.
The other day, traveling at high speeds (I'm usually a local driver) this product was making a lot of noise and some draft. The slightly increased noise over Freedom Panels I accept; the draft: not so much.
Noticing the latches weren't as tight on this product as the Premium Soft Top I loosed the bolts that keep attached to the rig the latch receptacles and moved those receptacles on each side of the rig (driver's and passenger's) as forward as possible (maybe 1/8" forward,) thereafter retightening the bolts.
This helped make the latches on the Sunrider a bit tighter, but is there any other adjustment that can be made to the Sunrider for a tighter closed fit?
