Best way to stop a thief from towing your Jeep?
txj2go
DFW
Not 100% sure, but I've always heard that civilians aren't allowed to own/use weapons with calibers that are used by military or law enforcement (while the cartels use everything under the sun).
That may very well apply to citizens of Mexico, tourists may not be able to even possess those. One stray 22LR cartridge under your seat may get you arrested.
entropy
Foothills of the San Gabriels
Jeep Wrangler Sport S JL 2-D
Professional dancer/male stripper
Whaler27
Alex
Oregon
Saving the world :-)
Yeah. National crime data are particularly befuddling, and always dynamic, though the worst five cities have been among the worst cities for at least two thirds of my life.
Small tweaks in law and other influences can have a profound impact too. In 1994 Oregon’s citizen-initiated “Ballot Measure 11“ overrode the Legislature and implemented a mandatory minimum sentencing structure for the most violent crimes. It ended Oregon’s imaginary sentencing and imposed certainty. It also eliminated “good time” for the most violent crimes, so a sentence of seven years started meaning seven years. As it turns out, lots of the pedophiles, rapists, and robbers are persistent, so if you incarcerate a few thousand of the worst of them it makes a difference. Less than two years after Measure 11 was implemented Oregon’s violent crime rate went from among the ten worst states to among the ten best.
Maverick909
Inland Empire
www.instagram.com
its this simple 2 wire shielded cable. Remove starter coil wire it to one wire and the other wire back to the coil. add a 50 cent toggle switch and hide it up under the dash or install it in the center consul might take an hour to do this
txj2go
DFW
I did that many years ago in my first car but not to any car since. That car was old enough that it actually had a coil and no electronics. Most cars now have a lot of coils so its harder to find a single wire to interrupt, maybe the power to the fuel pump would be an easy one.
Maverick909
Inland Empire
www.instagram.com
I splice it at the starter typically. pretty simply and you can tape and wire loom to match the factory stuff no one would ever know
trekster
Trekster
Golden Colorado
2022 JL Rubicon Extreme Recon
I’ve been using The Club for years when I’m concerned about theft. It locks on your steering wheel so the wheel can’t be turned. I guess thieves could still tow it or break the steering wheel but that would take more time and repairs.
5x5
Shaun
Nemesis2!
2021 JL Rubicon, 2020 JLU Willys Diesel, 2006 LJR
Boot a rear and front wheel. Can’t be towed frontwards or backwards.
LOL, you have never seen a repo wrecker. They have tire dollys that slide under the front tires for front wheel drive cars and hidden tow hooks that slide out of the bed of a regular looking truck. Can be hooked and gone in under 60 sec.
azjl#3
North AZ
2023 Sarge Green JLR
I'm still voting for gated garage, or we'll placed .40 round. That or chain it to a pole, real heavy chain.
No one can defeat a tow truck unless you sit by it all night, sorry
There are some cool tracking devices but now you are talking big bucks and they know how to defeat all of them
Bottom line, don't make yours the one that stands out, if it does, stay with it.
XT Carol
Carol
Arizona
2018 Jeep Wrangler JLU Rubicon 3.6L V6
We travel a lot and often park in hotel and motel lots. Is there anything that you do to make ulyour jeep harder to tow away?
I park between two vehicles, nose in first. Turn the wheels to full lock one direction, put the transfer case in 4low. This makes it very difficult to get it out of the parking spot and difficult to tow. Not saying these obstacles can’t be worked around, just saying it make the process way more difficult.
What strategies do you use to make your Jeep harder to be stolen?
I've read most of this thread and learned from the ideas. But a device I use for security in my remote campsites came to mind. I buy them from Amazon. They sense movement but not through glass AFAIK. But if a couple were set inside a Jeep, facing different directions, and one hung by a cord from the rearview mirror (thus moving if the Jeep were hit by another car), they will send a signal to the monitoring device. The signals have a range of 1/2-mile, as these are "driveway sensors". I put them up on trees and mounted to my RV, and if anything moves out there I am alerted to it. I keep the monitor beside the bed. They work well. So if someone entered your Jeep it would detect that movement, and if it was being hooked to a vehicle to be towed (thus shaking the hanging sensor), either would awaken you in your hotel room. Both sensors and the monitor are battery powered/rechargeable, so completely portable. At least if anything was going on with your Jeep you'd know it. That's when the "Glock option" would begin.
https://www.amazon.com/gp/product/B08GNSNRW4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&th=1
Sanchese
Carlos
Toronto, Canada
2021Rubicon, 2022 Rubicon Xtreme Recon on Order
I had my brand new 22 Rubicon stolen last March.
Was lucky enough to get another 22 Rubin in June.
I learned my lesson and had an immobilizer installed.
I also use the club on the steering and wheel and another on the brake.
I know it is overkill but I subscribed to xm guardian and I put 2 ipod trackers
