rhocking
What is the best way to Jump-Start for a Jeep with F42 fuse removed and Aux negative cable disconnected?
Specifically I have a jumper/booster pack 1000A that notes foo for all gas and up to 6.5L diesel engines).
I am assuming red to red/positive terminal connector on battery, but is it best to connect black to body ground OR to negative terminal connection on battery OR to bolt that holds negative cable to the negative terminal connection?
Does this best method change if using jumper cables vs booster pack.
