SlickRickMotoADV
- Rick
- Mar 9, 2021
- El Sobrante, CA
- 2019 Wrangler Unlimited Sahara, 2017 Miata Club RF
I have a Sahara JLU with an OME 2" lift kit running Rubicon OEM wheels w/ 33" MTs.
When shopping for lifts, I was set on AEV, until I learned that it would require new lower offset wheels or spacers (there is no reality where I will ever run spacers). When calling OME to discuss, they stated that they work with all forms of stock wheels/axles, which is why I chose OME.
When I installed the lift, I don't think I heard any issues out back, but my rear sway bar was tilted too far down for my liking.
To remedy this, I installed the Synergy rear sway bar drop brackets that drop the rear sway bar 1.5". You'll see this in the attached pics.
I now hear some noise that could be contact of the endlink, when going over bumps that hit a single rear corner. At rest, the endlink is definitely close to the control arm bracket, but does no contact when I jack up one side (either) from under the spring perch, nor does it contact when jacking it up from the diff skid, allowing full droop for both sides.
obviously if I'm hearing contact (supposedly) from big road imperfections on one side, that would be under compression not droop. My jack/stands don't have the height range required to attempt to drive a rear wheel onto the jack and compress it. I did that best I could, and see no contact.
One would think with the drop brackets installed that I would have LESS chance of this happening, not more.
There does not appear to be any contact on the shocks themselves.
Any thoughts as to what this might be? All pics attached are at rest on flat ground. Please let me know if any other videos or pictures would help.
