Sky King
Hey, I’ve never have been a car guy but now really excited about ordering a Jeep JL Rubicon. However, I’m little confused on the best wheel/tire combination to get the look I want and maintain original handling characteristics. Hoping someone can help me with my concerns. I prefer slightly bigger tires than the stock 33s, that extend modestly beyond the fender; about 1” to 2” looks right to me. I understand lifting comes with ramifications that can effect drivability and will not lift. The Rubicon is already an inch higher and can accommodate a larger tire. I would appreciate some help on the best wheel offset that gives me the sought after look but does not negatively alter handling, put excessive wear on parts and has zero rubbing. I have noticed that just a slight upgrade from stock 33 inch tires is really observable and now focused on Nitto Ridge 295/70r17 tires. I’m looking at three wheels that come in offsets of +25, 0, and -12. The Rubicon comes standard with a +45 wheel offset. I have used https://tiresize.com/wheel-offset-calculator/ to see how far the outer side wall goes out and how much closer the tire gets to the top of the fender with different offsets. I’ve also read mixed things about how far you should drift from the factory offset without a lift. Now the questions. 1). Without lifting is there a more favorable offset to choose where drivability is impaired the least and there is no rubbing? 2) This is kind of an opinion thing, but is there a preference for how far the tire sticks out considering I am not lifting? 3). Are there problems with stones kicking up beyond some point when tires are beyond the fender? I should also mention that I will opt for the heavier steel front and rear bumper. I understand that depresses the body down about ¼ to ½ inch. For the purposes of looks, I ruled out the Nitto 305/70r17 which was the original tire I wanted. I don’t think the extra weight will negatively affect the look on the 295s as much. But if someone can confirm the 305s fit my criteria, appreciate seeing a picture and knowing what wheel offset was used. I hope these questions are understandable and apologize for how basic they may be. Any pictures would be helpful.
