Mr.Smith
I messaged ARC on EBay and he had a setWhere did you get the blemished ones
Looks good. My Mopar tube doors are on the way. Glad the ARCs with work on themIf you decide you don’t like that option, the ARC hangers work great for both the regular and tube doors.
I bought the mirror talked about in this thread. Havent gotten them yet but the pics and the review seems promisingAre those Mopar tube doors? They look good! What’s your mirror solution? I already have the CMM mirrors and think the Mopar doors are mirrorless. Right?
I think I might add Arc hangers for the real doors, and keep the Off-Road Concepts hangers for the tube door storage. I have the wall space.
Those are Mopar tube doors. The mirrors are these - Chupacabra Offroad Rear View Side Mirror for UTV (Pack of 2) For 1.6" - 2" Roll Cage Bar Break Away w/Adjustable Arm (Driver and Passenger Side) https://www.amazon.com/dp/B01NAPANZE/ref=cm_sw_r_cp_tai_UD4OEbS1KQ180Are those Mopar tube doors? They look good! What’s your mirror solution? I already have the CMM mirrors and think the Mopar doors are mirrorless. Right?
I have those mirrors on the way. Any complaints?Those are Mopar tube doors. The mirrors are these - Chupacabra Offroad Rear View Side Mirror for UTV (Pack of 2) For 1.6" - 2" Roll Cage Bar Break Away w/Adjustable Arm (Driver and Passenger Side) https://www.amazon.com/dp/B01NAPANZE/ref=cm_sw_r_cp_tai_UD4OEbS1KQ180
Nope...they’re great. One of them was sliding down a bit on the tube door, but I just put some double sided tape inside where it mounts. They’re amazing for $40.I have those mirrors on the way. Any complaints?
Good to hear. I thought about wrapping the door with something under the mirror mount. I assume thats what your talking aboutNope...they’re great. One of them was sliding down a bit on the tube door, but I just put some double sided tape inside where it mounts. They’re amazing for $40.
Correct. They come with some rubber gaskets for that purpose that go between the mirror mount and the door. One of them held the mirror fine, on the other side with driving and vibration it would slowly slip down. The double sided tape between the rubber gasket and door worked great.Good to hear. I thought about wrapping the door with something under the mirror mount. I assume thats what your talking about
Nice use of space on that cart. Their web site is not great for the details of the door cart. Do you slide the doors in from the narrow ends of the cart in a bottom track and behind the retainer on top?Hey folks, I pulled my doors today. Here’s a pic of the Top Lift cart for tight garages like mine. The garage door just clears the Jeep doors.
Hi D, no you just lower the doors gently onto the soft rubber and use the plastic spring loaded clips to hold the doors on top.Nice use of space on that cart. Their web site is not great for the details of the door cart. Do you slide the doors in from the narrow ends of the cart in a bottom track and behind the retainer on top?
That seems pretty straight forward. Thanks for the info!Hi D, no you just lower the doors gently onto the soft rubber and use the plastic spring loaded clips to hold the doors on top.
If it’s not clear I will take a closer picture.
Be safe pal.
