gato
- Apr 4, 2021
- New England
- 2021 JLUR
This has always bothered me on my JL. Since both ball joints are pressed from the bottom and there are no C clips or other retainers, when a wheel is up in the air with a heavy tire/wheel combo, what exactly counteracts gravity from simply pulling the knuckle/ball joints off the axle C? I know the axle/bearing are attached (at least while intact), but the axle/bearing can move down a good amount (prob enough to pull the joints out of the axle C). And of course if the axle breaks there is no more help from them holding things up.Well done!! I had posted about this failure mode in another thread and several didn't believe it could occur. You are now another one of such an impossible failure.....
Unless I'm missing something there is only the friction of the ball joint pressed on the Cs fighting gravity, right? How is that a good design?
(P.S. not very knowledgeable on ball joints - I may be completely wrong)
