IPvFletch
It seems many of the aftermarket sway bar end-links in the various lift kits are crooked/bent... at least in front...
Some examples:
Rough Country
Rubicon Express
Even Mopar's are bent
Yet several others are not....
MetalCloak Game Changer:
Superlift
Most importantly, I ask because I am looking at Quick Discos, and they are straight... although they almost look like they have integrated spacers on one end...
Rock Krawler
JKS
Rubicon Express
None of the lifts should cause any kind of axle width change nor track bar core change, nor the axle being more offset one-way (>> adjustable track bars). Anyways, the bends are opposite, so it is as if the mounts changed making them wider. But they all install in the same places for the most part. JKS has you remove a tab but it's only to run a bolt more easily. RK's mounts on a bracket directly above, but in the same spot horizontally, again because of the bolt situation.
Any ideas????
Some examples:
Rough Country
Rubicon Express
Superlift
Rock Krawler
JKS
Rubicon Express
Any ideas????
