fuelfox4949
2021 jeep wrangler jl rubicon with 3.6l etorque 10,300 miles
i have a few odds and ends happen with my jeep over the year but its mostly been working good except over this weekend so i wanted to ask a few questions.
question 1
since day 1 the battery is always charging at 14.5 to 14.6 volts. even if its been on a noco battery tender to full.
i start it and it still sits at that voltage, being a mild hybrid others said this is normal. the only time it comes down into the 13.5 volts is if i drive 250 miles up north.
daily i drive 10 mins at 40 mph and 10 mins at 50 to 60 to work. nothing plugged in to usb to drain the battery not even a phone charger cord. and i dont leave the obd2 bluetooth scanner connected
i had a dealership tell me the stock batteries are junk but they would not replace it because it has not fully failed.
i have heard the stock battery can cause sensors to fail and go off... more on that in a moment.
i am to the point for piece of mind to go get a aftermarket battery from advance auto. thoughts on that?
question 2
over the weekend i got out of the blue the service 4wd, electric stability control and abs lights on, so i read the forums and pulled the codes with jscan and says abs fault and LR wheel sensor erratic.
i pulled the wheel sensors out of driver and passenger rear hubs and cleaned them, they did not appear to dirty but cleaned them up non the less, checked the wires up to the frame and the connections are clean and hooked up and the wires had no rubbing or wear spot.
cleared the codes and drove and it was fine for the night, next day i start it up and there back on. drove it to the store in 2wd and 4wd got gas, paid, and when i started to drive home the lights were off.
the only strange thing that has happened in the last 2 weeks is i remote start my jeep with the fob, i always watch to make sure it starts, i then ran to the kitchen for my work cooler and headed out the door and the jeep was off. not even 2 mins had passed.
i really hate the local dealer so avoiding them is a goal otherwise i will try a different dealer if this issues is something i can not fix.
anyway i did not know what subject to file this under so i came to the general discussion.
would love to hear others thoughts and ideas and what i should or should not check.
question 1
question 2
