Battery charger for 3.6L ESS
Dkretden
Denver, CO
2020 JLUR 3.6L
Folks:
I am no longer in a highrise and I now have a private GARAGE for my 2020 JL. I can now get a battery charger to keep my battery in good condition through Mountain winters.
I drive my Jeep a few times a week… but only about 7k miles per year and apart from a yearly road trip, mostly on short trips of a handful of miles.
anyone have a recommendation for a charger? I think that I might not want a trickle charger as the Jeep doesn’t normally sit for long periods. Rather, I‘m thinking that a “fast” charger may be what I want so that I can hook it up 3 or 4 times a year, top-up and keep rolling.
I have a NOCO “jumper box” right now Based on recommendations from this forum. …. Good brand? Recommend a charger model? Or, is there Something else that you personally use and like That you would recommend?
any help would be appreciated.
Yawnie'sPapa
Bill
Central Iowa
'22 JTO, '23 JLUR, '82 SX4, '73 P. Cardin Javelin
BatteryMinder.
You don't want to "fast charge" if I take your meaning.
Unless it's REALLY low, a 1500 mA BatteryMinder will not only charge, but will keep the battery up, and desulphate and so on.
I have 3 of them - I keep 'em on my lawn tractor and two cars and am about to order another to put on my JT since it's not getting driven as much lately - and may even put one on my wife's JLU 4xe since the 12v battery in that thing drops fast when sitting and she often drives only once a week, if that.
A good charger will deal with all phases of proper AGM charging and not just toss a big voltage at it shoving in as many amps as it will take.
Doesn't take much more than overnight to run the battery in my wife's JLU from 12.2 up to full with a 1500mA BatteryMinder
These are what I run - and love 'em -
https://www.batteryminders.com/1510-12-volt-maintenance-charger-desfulator-with-warranty
Dkretden
Dkretden
Denver, CO
2020 JLUR 3.6L
Thanks for the recommendations, Guys.
anyone have any tips as to where to attach the negative from the charger? Is there a good ground in the engine bay somewhere?
swampflyer
rick
florida
retired
There are several threads on this subject, just search and read the forum members as to what they use. A lot of valuable information . I have a GoPro 10 mounted with velcro on top of my fuse box with a plug in on the jeep. I just plug it in when ever it's not being driven.
deznut6
Ron
Las Vegas
24 2dr Willys, '06 Frontier
on my '24 that I flat tow ....opposite the battery against the "seam" between the inner fender and "hood" is a ground (-) terminal that I attached a ground plate to for the aux brake system...you don't need the ground plate just connect to that "circuit/terminal" - I also use a 10amp NOCO Genius 10 -hth
OldGuyNewJeep
Don
CT
azwjowner
Phoenix
BatteryMinder.
This is the exact same one I've been using for ~8 years now, on multiple vehicles.
OldGuyNewJeep
Don
CT
