ItsNo4RE
ah yes but they wont deal with egr/dpf deletes. its def the safest optionI’m sure you did and I also spoke to Green Diesel Engineering
According to their numbers looks like the gains are pretty mild from the Delete tune to the Compliant tune.It’s my understanding the HD Diesel tune is just reselling GDE. However, GDE provides them the delete tune since it’s allowed in Canada. If you want a GDE delete tune just order from HD Diesel.
I would go with the delete tune just to remove all the exhaust complexity and weight. That would free up room for an axualary gas tank. I will wait till my warranty is near complete. My state will be the last in the union to implement vehicle inspections.According to their numbers looks like the gains are pretty mild from the Delete tune to the Compliant tune.
For example
GDE Compliant
+33 HP
+50 Lb Ft Torque
+2 ~ 4 MPG
HD Diesel Delete Tune
+45 HP
+85 Lb Ft Torque
+2.9 ~ 5.5 MPG
So by deleting you only gain
12 HP, 35 Lb Ft Torque & 0.9 ~ 1.5 MPG over the compliant tune.
Doesn’t seem worth the risk to me of not being able to pass smog ever again here. Unless I beat the guts out of the stick units which would be a lot of work and still just as illegal. Plus I’d be crossing fingers to pass when smog time rolls around.
For me I’ll be going compliant for sure since I live in Eco-Nazi California and this is my daily.
California will suspend my registration if they figure out any of the emissions crap was messed with.I would go with the delete tune just to remove all the exhaust complexity and weight. That would free up room for an axualary gas tank. I will wait till my warranty is near complete. My state will be the last in the union to implement vehicle inspections.
it isn't a lot of parts at all... its really just the dpf that you have to keep. slap it back on via welded on flanges and get your inspection... take it off right after. this really would only take you half an hour a year...California will suspend my registration if they figure out any of the emissions crap was messed with.
Which would be extremely unfortunate as the cost to replace all this shit would be like 10k+ if you took it all off and got rid of it.
Or save an enormous pile of parts to collect dust. Neither sounds great
You don’t think they would be looking for an SCR, entire EGR system, or DEF tank since it’s a 2021?it isn't a lot of parts at all... its really just the dpf that you have to keep. slap it back on via welded on flanges and get your inspection... take it off right after. this really would only take you half an hour a year...
CA does it through the OBD port as well. I don't know what it looks for so I haven't tried it with the tune installed on my Duramax though. My tune disables the EGR and I thought that the smog test checks to make sure the EGR is working properly. (probably just checks for codes) Since I use a handheld programmer, I simply reinstall my factory tune. My dad's Banks equipped truck, he just turned it off and it passed fine. Smog inspection shops are supposed to do a visual check as well to make sure everything is intact and also blip the throttle to check for smoke. I've never seen that done though.Here in Ohio you can do the emissions test via the OBD port. I can tell you for a fact that I have a friend that has a highly modified 996 turbo with no cats. The ECM program tells the OBD port test everything is okay and passes the test every time.
Would be cool if my friend could do the same thing with his diesel Jeep.
One other thing my friend has done with other modified cars. Again in Ohio. You can provide them with receipts of over 5k in modifications and apply for a collector plate. The collector plate is exempt from the emissions test.
You took the words right out of my mouth.OK so what’s the trade off? You can’t have more power, better mpg, less soot loading, less EGR use, and less SCR use without sacrificing something. The only way all of those things come together with zero sacrifice is if Jeep’s engineers purposefully created a less efficient, less powerful, less reliable system with no upside to any of it.
But Thats exactly what they did.... All done to appease the new EPA standards.You took the words right out of my mouth.
Except that 3rd party tuners are reportedly able to pass emissions standards with better fuel economy, better power, less DEF, fewer regens etc. FCA doesn’t have a vastly different tune simply to appease the EPA/CARB. They are weighing trade-offs that the tuners aren’t transparent about or simply don’t understand.But Thats exactly what they did.... All done to appease the new EPA standards.
