dave12345
Hello,
I have looked around quite a bit but it seems I cannot find much installation explanation for the Baja Designs XL-R Sport lights. I thought it would be similar to the non-XL Sport lights, but the harness seems to be different and I am not sure what to do to remove the switch properly, as well as the relay and fuse (should I remove that?) to connect all that to my JL auxiliary switch.
The harness has separated connectors for both lights all going to the relay, but if I remove the relay, how can I plug both lights to the same aux switch (I'd like to use #3).
I think I do not need the relay and fuse (and switch, obviously), as I will use the built-in JL aux switch bank that contains all that is required. I am not that much of knowledgable in that kind of electrical stuff, but I thought I'd be fine to go if it was similar harnesses to the non-XL, but now I think I'd prefer to have some help about all that.
So, does anyone know where I could find such explanation/instructions? Anyone done it and could give me some cues?
Thanks a lot!
Thanks a lot!
