SCOverlander
- Jeff
- Jun 26, 2020
- Bay Area, CA
- 2021 JL Rubicon Diesel
I installed these on a 2021 JL to replace the factory led fog lights. When I on turn the fog lights (from factory switch) they both come on but one side will turn off after a second. I have checked and there isn’t a short or loose wire. It is like there is to much draw and a fuse will trip.(which will reset on its own)They were installed to the factory fog light plug which has three wires. A black(ground) and two hots. I did not use the factory bumper harness but used part of the huge harness that comes from Baja Designs . Any of you run into the same issue? Thanks.
