Headbarcode
- Mike
- Aug 16, 2018
- LI, New York
- 2019 JLUR Stingray 2.0 turbo
- Vehicle Showcase
- 1
All 4 of the LP4's are mounted directly to the bumper, using the brackets that came with them. I drilled the bumper for the 2 center ones, but used an existing bolt hole for the outers. I removed the threaded clips and the torx bolts, so I could use the supplied mounting hardware.Did you use the Baja bracket and just bolt it to the two bolts on the bumper? Cant really tell from your picture. Thank you for the pictures, this is making it easier for me to pick out the parts I need.
My original plan was to install the 2nd pair on top of the bull bar, via a couple of bar clamps for a 2.5" tube, but the lower pair of lights didn't leave enough space for the clamps. The outer location was used just to get them installed and wired up. I'm not liking that spot, because it interferes with using the recovery hooks.
If you want more pics, from certain angles, don't hesitate to ask.
