Baja Designs are Not JL Rubicon Friendly
  1. texasyj2009
    texasyj2009 Member
    First Name:
    Philip
    Vehicle(s):
    1990 Jeep Wrangler YJ 4.2L ; 2019 Jeep Wrangler Unlimited Rubicon 3.6L
    Nov 3, 2017
    Liked:
    Garage Profiles:
    Yeah that was my plan, I definitely want to keep it simple if I can and without shorting the electronics in my Jeep lol I definitely appreciate any help you can offer.
  2. DanW
    DanW Well-Known Member
    First Name:
    Vehicle(s):
    Mar 2, 2017
    Indiana
    5,323
    Liked:
    6,053
    Garage Profiles:
    I'll look at it when I get a chance. Work has killed me this week, so I'm now laying on my ass with my computer. It may be days before I can muster the motivation to get up! Lol! Seriously, I'll try and take a look at it tomorrow and let you know how I did it.
  3. Shepherd12
    Shepherd12 Well-Known Member
    First Name:
    Josh
    Vehicle(s):
    18 JLR HellaYella m/t
    Dec 12, 2018
    Wilds of PA
    230
    Liked:
    238
    Occupation:
    Something about cryogenics
    Did you end up doing this?
    It’s too bad you couldn’t run the Spot off your fog light circuit (if you’re like me, and don’t have factory fogs anymore)
    Then put a relay&switch on the driving lights to come on with your Jeep’s high beams. Aftermarket lighting with factory controls.
    And does anyone have driving vs spot night shots? Maybe a YouTube video? I haven’t found a well conducted review yet. My factory halogens are not inspiring much confidence and I want to upgrade my lighting situation soon.
  4. 2Wheel-Lee
    2Wheel-Lee Well-Known Member
    First Name:
    Lee
    Vehicle(s):
    2020 JLUR on order, 2006 Dodge Ram 2500 CTD, 1986 Suzuki Samurai, 1975 Datsun 620
    Oct 11, 2018
    Orange County, CA
    298
    Liked:
    188
    I just installed a pair of LP6 lights onto my JLUR.
    Since I no longer have fog lights in a bumper, I powered each LP6 low beam off of each fog light circuit.
    I connected the high circuit off AUX 1.
    NOTE: BD is very clear that the low beam should never be powered at the same time as the high beam. To prevent me from accidentally doing this (driving with fog circuit on and AUX 1 on), I installed a couple relays triggered by the AUX 1 circuit to interrupt the fog circuit to the low beams.
    I did run into an odd challenge. My JLUR came with LED lighting. The fog circuit didn't work the low beams - they'd just flash on once in a while. Using my Tazer mini, I changed the fog lights from LED to standard, and now the fog circuit runs the LP6 low beams just fine.
    I think the term low beam isn't quite accurate - it's really the wide pattern and high is wide and spots, so excuse my possible incorrect use of terminology - I don't remember what it actually is.
  5. hawgwld
    hawgwld Active Member
    First Name:
    Hawgwld
    Vehicle(s):
    2020 JL Unlimited Rubicon
    Oct 12, 2019
    Seattle
    Liked:
    Hey could you please send me your wiring diagram? I am wanting to do the same...I was just about to tear into the harness and thought surely someone else has figured it all out. THANKS!!!!
  6. texascrane
    texascrane Member
    Vehicle(s):
    2020 JLUR, 2006 100-series Landcruiser, 1985 CJ-7
    Nov 9, 2019
    Liked:
    I'm enjoying the LP6's on my 20 JLUR. They are very bright. 0FF02156-9613-4446-BC86-792A2A0B7B2C.jpeg
  7. Jgeiken
    Jgeiken Well-Known Member
    First Name:
    Jesse
    Vehicle(s):
    2018 JL Rubicon
    Nov 21, 2018
    Roscoe, IL
    100
    Liked:
    70
    Took a few hours and wired these in today.
    Used two relays to accomplish the following.
    AUX 1 on: LP6 high mode comes on and off with vehicle high beams, no low mode
    Aux 3 and AUX 1 on: low mode on with vehicle low beams and high mode on with vehicle high beams. High beams kills power feed to low mode wire.
    This seemed to be the best solution for me as I can have the high mode on and completely kill it by switching off headlight high beams. I can also run the lows and highs actuated by the vehicle high beams with both aux buttons activated without feeding power to both wires and frying the lights.
    mikej and DanW like this.
  8. zscooby
    zscooby Well-Known Member
    First Name:
    Tony
    Vehicle(s):
    2018 JLU white Rubicon
    Mar 11, 2018
    CT
    65
    Liked:
    I use the SPOD plus I wired in a relay to make sure the high and low are
  9. zscooby
    First Name:
    Tony
    Vehicle(s):
    Mar 11, 2018
    CT
    65
    Liked:
    Looks great! Mine are wired to come when the high beams come on, low beams with the lows and the parking lights with the key. They all can be shut off or turned on independently as well. Great lights.
  10. zscooby
    First Name:
    Tony
    Vehicle(s):
    Mar 11, 2018
    CT
    65
    Liked:
    No, I bought an SPOD wired them directly to it, put a relay in so they can’t be on at the same time. I could have wired the the low to the oem fogs, because the only draw 7amps according to my SPOD and Baja designs. I wired up a pair of rigid side shots off the fog lights. They work great.
  11. AnthemAVM
    AnthemAVM Well-Known Member
    Vehicle(s):
    Jeep JL
    Apr 29, 2018
    92646
    245
    Liked:
    153
    Looks sharp
  12. RubiCoug
    RubiCoug Member
    First Name:
    Justin
    Vehicle(s):
    2017 JKU
    Jan 11, 2020
    Seattle, WA
    Liked:
    Why not just skip the lows, and only wire in the highs?
  13. Jgeiken
    First Name:
    Jesse
    Vehicle(s):
    2018 JL Rubicon
    Nov 21, 2018
    Roscoe, IL
    100
    Liked:
    70
    The high beams are insanely bright. The lows seem to work well in poor weather where the high beams are best for back country/ off road driving. I wouldn’t use either mode in traffic though.
  14. texascrane
    texascrane Member
    Vehicle(s):
    Nov 9, 2019
    Liked:
    You shouldn't be using these lights in any mode on public roads. You're going to end up with one hell of a ticket.
    I only wired the high mode on mine. I don't have a need for a lower brightness mode.
  15. DanW
    First Name:
    Vehicle(s):
    Mar 2, 2017
    Indiana
    5,323
    Liked:
    6,053
    Garage Profiles:
    Just an FYI, I've had these a little while now and can tell you without a doubt that they are warm enough not to freeze over. I had mine covered with a layer of ice last weekend in a snow squall in the UP of Michigan. They melted it right off with no problem.
Loading...
Share This Page
