Bad bolt! Can’t remove rear camera cover
jeep4xelover
jeeplover
GA
Jeep Wrangler Sahara 4xe
The bolt goes bad. What should I do?
shitty Jeep can’t even use a quality bolt for a 60k+ car.
Jeep Wrangler JL Bad bolt! Can’t remove rear camera cover AFC6E68F-76E8-4AF3-AB74-74129D9925B6
jeep4xelover
jeeplover
GA
also where can I get a metal one to replace the factory plastic one?
Dyolfknip74
Ottawa, Ontario, Canada
2021 JLU Rubicon
Sent it a little hard with that torx bit eh?
There isn't a metal one that replaces OEM but there are options if you get a new carrier.
Should be a lot of people that have them laying around though.
ConqSoft
Keith
Wake Forest, NC
2020 JL 2 Door Rubicon 6 Speed
Systems Analyst
Yeah, that isn't meant to be torqued down. It's just a basic fastener that you give like a half twist to put on and a half twist to take off. Someone went to town on that!
dragoneggs
Seabeck, WA
'22 Snazzberry Pearl JLR
Yeah I almost did that. It turns easily from lock to unlock. Does NOT unscrew!!!
Make sure it is in the unlock position and then you have to wiggle and pull the cover straight off. I was getting frustrated and then read the instructions.
YippieKiYayMrFalcon
Rob
Atlanta
2021 JLU 80th Anniversary
jeep4xelover
jeeplover
GA
  • Haha
Reactions: GtX
dragoneggs
Seabeck, WA
Yes. I realized that. Now I can’t get it back to locked position!!
Well, hopefully it is unlocked and you can just pull it off and replace it with new and forget about it. Yep $10.
jeep4xelover
jeeplover
GA
so basically it doesn't lock anything. it just move tiny screws inward and make it tight. There's bar that you can push which does the same thing.
jeep4xelover
jeeplover
GA
Any local stores might have it?
