Backup LED above the camera behind the spare tire
  1. MacJack
    MacJack Well-Known Member
    First Name:
    O)|||||(O Jack
    Vehicle(s):
    2018 Rubicon JL 2 Door
    Aug 9, 2018
    Western NC
    407
    Liked:
    216
    Garage Profiles:
    I'm' seeking wisdom and comments from you guys who ever looked at this as a location for backup LED... I want to put a LED flood like in the hole or top spoke of the attached photo. Nice place to mount it on metal.
    Anyone who did this an and what LED light did you use or would like to suggest..
  2. Rhinebeck01
    Rhinebeck01 Well-Known Member
    Vehicle(s):
    5/2/19 ....... I quit JLWranglerForums!
    May 9, 2018
    4,387
    Liked:
    4,839
    @MacJack
    To me that is to high up for a b/u light. Would be easy to mount an LED there but............
  3. Goin2drt
    Goin2drt Well-Known Member
    Vehicle(s):
    18 Rubicon, 17 Grand Cherokee Trailhawk
    Oct 25, 2017
    Kentucky (formerly Peoples Republik of Kalifornia)
    1,396
    Liked:
    1,411
  4. DickZip
    DickZip Well-Known Member
    Vehicle(s):
    2018 Jeep Jl Rubicon
    Mar 13, 2018
    Vegas
    333
    Liked:
    366
    You 60C36837-874B-4FC5-AE95-F21598E446BC.jpeg want them low
  5. OP
    MacJack
    First Name:
    O)|||||(O Jack
    Vehicle(s):
    Aug 9, 2018
    Western NC
    407
    Liked:
    216
    Garage Profiles:
    Thanks for all your comments... Keep them coming...
  6. Rhinebeck01
    Vehicle(s):
    May 9, 2018
    4,387
    Liked:
    4,839
    @MacJack
    I went with Rigids, (they are 1"x1" in size) mounted low as they should be mounted.. They go on when I place tranny in R and I can also toggle on with Aux 3 which I have set up with it. Install of the Rigids was so very easy..
    Some guys have two LEDs mounted on either side of the receiver hitch. There is a vendor that sells LEDs with a bracket that kinda cradles the receiver hitch.. I do not care for that because of the proximity to the receiver hitch..
    Here is my install.
  7. JIMBOX
    JIMBOX Well-Known Member
    First Name:
    JAMES
    Vehicle(s):
    2018 HELLAYELLA JLU SAHARA/2016 "STINGER YELLOW" RAM
    Feb 19, 2018
    FERNLEY NV
    1,649
    Liked:
    1,528
    I installed my OPTIMA HALOGENS 55w on the rear bumper TOP/EACH SIDE
    They're operated by AUX 2--at any time
    W.E.
    JIMBO
  8. OP
    MacJack
    First Name:
    O)|||||(O Jack
    Vehicle(s):
    Aug 9, 2018
    Western NC
    407
    Liked:
    216
    Garage Profiles:
    You guys have lived up to my expectation with so many options and advise.... so many good ideas. Thanks.
  9. bentaxle
    bentaxle Well-Known Member
    Vehicle(s):
    2018 Rubicon
    May 16, 2018
    New Jersey
    60
    Liked:
    55
    Garage Profiles:
    Be nice if they would make lights to fit the two red reflectors in the steel bumper.
    Tx_Longhorn_Fan and drock317 like this.
  10. Rhinebeck01
    Vehicle(s):
    May 9, 2018
    4,387
    Liked:
    4,839
    I'm sure in a year or whatever there will be such an offering. I will easily move to that offering when available.
    Can always use the little Rigids l currently have in another application.
  11. Rhinebeck01
    Vehicle(s):
    May 9, 2018
    4,387
    Liked:
    4,839
    @MacJack
    Here is a pic of the VisionX, b/u LED light offering. cost is approx. $349.
    Very pricey, and I just don't care for the look of it or it's proximity to the hitch receiver and to the 4/7 pin connector box. Would be an easy install though.
    If you wanted to hook up to Aux switch and also b/u wire in hitch wiring bundle, you would need diodes. No big deal but another say $30.
  12. kkuntz01
    kkuntz01 Well-Known Member
    First Name:
    Kevin
    Vehicle(s):
    2018 JLU Rubicon, 2014 Ram 2500 Crew Cab
    Jan 20, 2018
    Glendale Heights, IL
    921
    Liked:
    665
    Why do they need to be low? If you’re using a quality light that does a good job of projecting light they don’t need to be low.
    This pic just to show where the were mounted on my JK.
  13. DickZip
    Vehicle(s):
    Mar 13, 2018
    Vegas
    333
    Liked:
    366
    I prefer a wide low spread, if u have a backup camera and your lights are not low I run the risk of blinding the camera and anybody else that’s behind you. But U can do Whatever U want. The above photo shows what I don’t want. Kk do u have a JL?
  14. Rhinebeck01
    Vehicle(s):
    May 9, 2018
    4,387
    Liked:
    4,839
    Yup, no way would I ever consider mounting b/u lights up high like in that picture..... and, for a whole bunch of reasons.....
  15. kkuntz01
    First Name:
    Kevin
    Vehicle(s):
    Jan 20, 2018
    921
    Liked:
    665
    Yeah I do have a JL. The pic’s I posted we’re more to illustrate light output mounted at that level. The lower to the ground the lights are, the less usable light you get in my experience (I’ve got a set mounted below the rear bumper on my wife’s Ram). With the back up cam on on the back of the JL it wouldn’t be doable to run a similar set up, though one might be able to fab something poke up over the spare mitigating the whole blinding the camera thing.
    Now as far as blinding someone, that should be a non-issue unless you’re doing intentionally (i.e. a f-you light). It’s a rear facing light so it’s not as if it would be flipped on when you’re driving forward, right? You’re going to be using it at night, probably when no one else is around. If you’re in a group with someone behind you there is no real reason to flip it on unless you’re using it as a chase light, and in those situations the person behind you will be far enough behind that they won’t be blinded.
    That’s the way I look at it at any rate.
Loading...
Share This Page
