Back Window Cracked Overnight
WhtRubi
San Diego
2021 JL Rubicon
Woke up this morning to a nice crack in my rear passenger window. 2021 JL Rubicon 2-Door, 20,000miles
Jeep Wrangler JL Back Window Cracked Overnight 20221215_083827
Seems to be from the inside of the glass, and appears to be in the area of the center bolt for my hardtop. I've never removed the hardtop, so everything is torqued as it came from the factory. I don't carry anything in the rear, so it wasn't an impact from anything getting jostled around.
My only guess is that it got pretty cold last night (~40 degrees... It's cold for San Diego), and the change in temperature constricted the hardtop enough that it broke the glass.
Has anyone else had this problem or know what could cause this? Interested to hear your takes
1Evil55
here
2018 Sport
That sucks. I doubt the temps would have much effect as 40 isn't that cold, coming from Chicago. Maybe if it were your windshield I'd agree more. Just thinking that the cold air outside and the windshield getting defroster heat on inside. I have a crack on mine and was able to watch the crack grow last week from difference in outside/inside temps. Could it have come from the middle bolt? You said you've never touched them. If that were the culprit it probably would have happened a long time ago. Sorry to see it happen to you.
Fitzz47
Jim
Delaware
2018 unlimited Sahara jl
It happened to my sons jeep. The tech who replaced the glass said he has done a few. He suggested leaving your drivers window slightly cracked when you close a door. He claimed closing the door hard made enough pressure to crack the window. It’s been ok since
Bulletbill
Tom
Central PA
2021 JLUR
Is there anything blocking the vents in the rear? I have heard some stories of people who had tailgate tables which blocked the rear tailgate vents and it caused the jeep to over pressurize when shutting doors causing the glass to crack or break.
calemasters
Allen
Springfield, Mo.
2026 Moab 392 w/27X package & Escalade
Retired Mechanical Engineer
Could be an irregular window bed in the fiber glass roof that caused a stress fracture at the bottom on the glass side window. When the cracked glass is removed, someone should carefully inspect the window bed at the bottom where the fracture occured.
WhtRubi
WhtRubi
San Diego
2021 JL Rubicon
Nothing is blocking the rear vents. It would be strange if closing a driver's door caused the side passenger window to crack, but it's all pretty strange anyways
WhtRubi
WhtRubi
San Diego
2021 JL Rubicon
Interesting. I'll have to have the tech look into it when I get the glass replaced. Probably get it done at the dealership so if it is a bad hardtop, it can be covered thru warranty. Thanks for the info!
Reinen
Utah
2021 Jeep Wrangler JL Rubicon
40 degrees isn't exactly cold, but how warm was it during the day? It's the temperature difference and how quickly it changed that matters. If it was temperature.
Here's some other things I'd check.
Insure all hard top bolts are tight. It could have cracked because the bolt near the crack is tight and others are loose allowing movement.
Is there a roof rack or bars that's only supported by the hard top? Maybe too much weight up there?
All the other responses are also possible causes of the crack. It could be many things, gotta check them all.
calemasters
Allen
Springfield, Mo.
Some dealers replace glass while others sublet to a local glass shop.
WhtRubi
WhtRubi
San Diego
2021 JL Rubicon
No roof rack or other mods on the hardtop... The only thing close is a hardshell locking tire cover which weighs next to nothing, so I don't think weight would be the cause. I'll have to check the bolts, I honestly haven't touched them since I've never removed the hardtop.
WhtRubi
WhtRubi
San Diego
2021 JL Rubicon
Understood, but I like keeping all maintenance records in one place. IMO it helps with resale value and allows for tracking of chronic issues
Bill_P
Bill
Orange Va
2018 JLU, 2023 JLUWSXR
Can't tell you..shhh
That and if you take it to Safelite or somewhere on your own dime, it gives the dealer an out to say that whatever damage was caused by them and it isn't covered under warranty. If the dealer contracts them, the dealer is still responsible.
WhtRubi
WhtRubi
San Diego
2021 JL Rubicon
Absolutely! Plus Safelight will in all likelihood use non-OEM glass, vioding whatever warranty there would otherwise be
jaymz
Jay
Inland Empire
2018 Rubicon Unlimited
That’s odd. I always assumed that the side glass was tempered. Tempered glass doesn’t crack like that.
Bback58
Bismarck, ND
2025 Wrangler Rubicon X , 4dr, Auto & 2021 Wrangler Willys, 2 dr, 6 spd,
Warehouse receiving mgr.
Normal temperature change isn't going to crack your glass. Once there is a crack, then it can.
I didn't think a side window would crack - I thought they were tempered glass and if something happened they would just shatter.
