Aux switches - Im Looking for instructions
mlotero
Mauricio
Boynton Beach
JLUR
Sr IT Manager
Anyone has documentation or step by step guides? I want to install a light bar on my bumper using the aux switches
Torero
J. Diego
Illinois
JL Rubicon, FJ Cruiser, BMW Z3, F650,GL63 AMG, STI
There is some level of explanation in the owner manual.
OnlyOne
Northwestern New Mexico
2021 Gladiator Overland Diesel
Really nothing to it. Run a wire from your harness wire of your choosing under the hood, to your lights. Done. Two 40 amps and two 15 amps are your choices. 5-10 minutes maybe. It will take you longer to mount them, than wire them.
Lurvis33
Luke
Lewisville, TX
‘18 Sting-Gray Sahara
I’ve done a lot of looking into this as well and I’m still confused which color wires are which for the two 40 amp and the two 15 amp.
OnlyOne
The two 40 amps are the larger wires.
Aux 1 = pink/tan 40amp
Aux 2 = green/purple 40amp
Aux 3 = orange 15amp
Aux 4 = purple 15amp
Lurvis33
Luke
Lewisville, TX
Woah, looking back at the picture from another thread, I never noticed they were different thicknesses. It makes perfect sense now, thanks! :idea:
TroyBoy
Troy
Vancouver Island, Canada
Thought I would share my wiring mess:
Notes:
The Aux1 and Aux3, RED tags, are capped off becuase I used the wires in the engine compartment for them.
The two big red wires(12 and 14awg) are WAY WAY overkill but it is what I had so I used it.
Aux2 is 40amp so I added a fuse because my compressor wire just runs a relay using a 2amp fuse.
Aux4 is 15amp and directly runs my LED reverse lights which I do not have yet. No fuse needed as 15amps is fine.
Aux1 is 40amps and it also just runs a relay in the engine compartment. Do not hook a winch directly to aux wires!
Candsevo7
simon
United Kingdom
CRD JKU x2 , 2.2 JLU
where are the ends of the wire located ? are they factory fused ?
Stry
Bob
Wellsboro, PA
2019 JLUR
Per the Owner's Manual, they are factory fused. Connections are located under instrument panel and under hood behind battery.
Freeland Jeep
