AUX Switches and LED Lights
Techbrute
Tim
DFW
2020 Jeep Wrangler Unlimited Rubicon, 2000 Jeep Wrangler Sahara
Everything I can see tells me that there are 15A and 40A relays or fuses in the AUX switch circuits. I am wanting to tie a pair of KC Gravity Pro 6 lights (1.63A each, 3.26A total) and a KC Flex 10" lightbar (5.0A Total) both to one of the 15A AUX switches, and I wanted to make sure I didn't need to install a separate fuse or relay inline. With only 8.26A draw combined among all the lights, the load should be fine, but I did want to make sure that there was some sort of circuit protection in place in case a short develops.
nerubi
Nebraska
2019 JLR, 2020 VW Tiguan
The wire to the aux switch is fuse protected. If you connect to the provided wiring and do it correctly it should be ok. I have 2 KC gravity led lights on one switch, no relays or extra fuses.
Clayton Offroad
