Aux switches - accessories exceed fuse capacity
tiltz
Dustin
Washington
Subaru STI
I bought an ARB twin compressor that has 2 40 amp fuses, a vision x light bar that has 2 30 amp fuses, and vision x pod lights that have 2 10 amp fuses. None of the mopar switches are rated high enough.
What's the best way to wire these in while maintaining most of the accessorie wire harness that has the correct wire gauge and fuse size. I'd assume just cut off the switches from the accessories? One wire needs to connect to the mopar wire and the one to a power and one to a ground?
TroyBoy
Troy
Parksville
Sheepjeep
Ma
01 xj, 04 Silverado 2500hd
When dealing with switches that Canton handle the load you plan on running relays become you friend
Done Right LED
