BobK
- Bob
- May 24, 2018
- Parker, TX
- 2018 JL Rubicon Unlimited
- Occupation
- Semi-Retired
- Vehicle Showcase
- 1
Does this look correct to you? Between your instructions and what I read from WARN, this looks correct. But as in the old carpenters saying "measure twice, cut once" I wanted to check with you since you too have the Warn Power Interrupt kit.That’s how I understand it.
You’d connect the battery power to the interrupt unit and then to the winch. Then the aux switch power would be connected to one of the small terminals on the interrupt unit while the other small terminal is connected to the negative terminal of the battery. I don’t think it matters which terminal either as they are not labeled.
Link to instructions just in case.
https://www.gowarn.com/aux_incl/pdf.ashx?pdf=WAR_62132_INS_1.pdf&line=WAR
