Aux Switch Panel - Loss of all power
BluRubicon
Bradenton Fl
2018 Jeep JL Rubicon Ocean Blue ord’d 5/21, Enclave, Harley Ultra Glide
I've loss all power to the Aux Switch Panel. All switches 1-4 = no power.
I've pulled and looked at F72, F92, F93. I've pulled and re-plugged in K17 & K 18.
I still get nothing.
So I looked at Post N4 and there's no bolt and no wire? Did my Wire drop? It's a different look than the other post. Can someone look at your N4 and let me know what you see? My pic is attached. I'm just wondering before I start climbing underneath with a new knee.
FYI - I had a shop install Well Lights AUX 2 and the glow of Baja Design 6's set to Aux 1. I have lost power previously to these and regained power for unknown reasons.
parbo
San Diego
I aux switches and it is the same as your picture.
BluRubicon
BluRubicon
Bradenton Fl
Yes, Aux Panel Factory Installed. I lost power to all Aux Switches.
@BluRubicon
?... were your Aux Switches, installed at the factory..
That one post is as it should be.... with nothing attached...
Rhinebeck01
2018 2dr. Rubi
@BluRubicon
The reason I asked is because the Aux that you buy from Mopar and you add after factory build, has a 5 amp fuse on it and if that fuse blows, none of the switches will work. I do not think/I'm not sure.... if the factory installed Aux has such a fuse..
When whomever fooled with your Aux... installed those mentioned lights, etc., did they happen to be pushing wire through the grommet in the passenger side firewall?
parbo
San Diego
Glad it worked out.
Rhinebeck01
2018 2dr. Rubi
Glad it worked out.
@parbo
I'm not the OP, so not sure if it is the remedy..
My guess is it is..
OP, reported intermittent Aux switches going out and now all are out... Sure looks like that TSB is the fix. We will see what OP, says..
BluRubicon
BluRubicon
Bradenton Fl
jlrusoin
Sean
Indiana
Jeep JL Rubicon
My aux switches have lost all power. The lights do not come on and they do not function. The service bulletin is not the issue, the switches are snapped together well. The fuses are all good. The batter is new and reading greater than 12 volts. Any other thing I should look at before purchasing new switches? Does anyone know what voltage should be on the wires in the plug? Thanks
Rubitrux
