Dkretden
- David
- Jan 29, 2019
- Denver, CO
- 2020 JLUR 3.6L
Are they referring to the main battery negatives only or the negatives on frame? Or both? im guessing that it’s just the negative on the battery but I figured I would check.Here is a snip from the Factory Service Manual.. Note, that the service manual says to first, Disconnect and Isolate the negative battery cable(s) . IMPORTANT --They are referring to the negative battery cables up top / in the engine compartment, on the Main battery!
After doing that, you remove the 3 bolts from the supplemental battery tray (Aux's battery tray) and lower the Aux battery down a bit.... just enough so that you can get to and disconnect the pos and neg cables (then isolate them) from the Aux battery. After both the cables are disconnected, your Aux battery is free to drop down and to be replaced.
