Aux. 4 not working? Help!
HeavyMetalFox
Chic-ette
Fruitvale BC Canada
2020 JLUR Recon Edition
RMT
My bf installed some rear pods on the jeep bumper and they worked for a bit then stopped. The light still comes on the switch itself when it’s pushed but the pods don’t turn on. He’s checked the wiring and all seems good. When he unplugs the wire and attaches them directly to the battery they work. So he thinks it’s a fuse but he’s checked all the fuses in the box under the hood on the passenger side and he doesn’t think any of those fuses are for it. Is there another fuse box for the Aux buttons or do you have any ideas? Thanks in advance guys
Rhinebeck01
Multiple places..
@HeavyMetalFox
F108 HD ACCY #4 — 15 Amp Blue Micro fuse is the fuse in the PDC that protects Aux 4. Check that and you might, even if it looks ok, replace that fuse with another 15 amp fuse.
Also, check the ground for the goodie that is hooked up to Aux 4.
Rhinebeck01
Multiple places..
For those that read through this thread .....
With Factory installed Aux switches, here is the fuse list in regard to Aux .... Aux 1, 2, 3, 4, and also the Direct to Battery and Ignition Switched, wires which are only found in the passenger foot well, Aux bundle.
These fuses are found in the power distribution center (PDC) next to the Main battery.
F50 HD ACC — If Equipped 10 Amp Red Micro < Ignition switched wire in pass foot well
F72 HD ELEC ACC PKG — If Equipped 10 Amp Red Micro < Direct to battery in pass foot well
F92 HD ACCY #2 — If Equipped 40 Amp Green Cartridge < Aux 2
F93 HD ACCY #1 — If Equipped 40 Amp Green Cartridge < Aux 1
F103 HD ACCY #3 — If Equipped 15 Amp Blue Micro <Aux 3
F108 HD ACCY #4 — If Equipped 15 Amp Blue Micro <Aux 4
Rhinebeck01
Multiple places..
