I unfortunately missed the build tracking spreadsheet so I've been manually checking the Window Sticker and Build Sheet pages for my supplied VIN number for the past few weeks religiously.
I finally decided to make a small tool that I run on my PC that just checks it periodically and will notify me when it's available. From what I hear that means it's at least progressing through the build stages.
I wanted to help others, but figured nobody would want to run a random strangers .exe on their computer so instead I made a tracking website that you put in your vin, a nickname and an email. When the sticker and build sheet are available it will email you so you don't have to continuously check yourself.
This tool is now available at: JLWF JL Tracking Tool: Window Sticker and Build Sheet Lookup
VIN: This is the vin you are trying to track
Nickname: This is the name that will show next to your partial vin on the homepage
Email: Used to notify you
If you put in your info it will get added to the list for checking. If you then come back later and put in just the VIN it will pull up the full VIN, instead of a partially blocked one, and then also give you status with clickable links. I hope to get the emailing part up and working tonight.
Hopefully some of you find this helpful while we wait.
**EDIT**
I've fixed the timestamps to show the last time the data was checked on a per-VIN basis. Once both Sticker and Build info are found the date should be the last time it was updated.
Automatic emails should now be working. If either of the items changes you should get an email with links.
I also added some stats to the top of the page for fun
**EDIT**
