GregorioJL
- Greg
- Jul 13, 2020
- Germantown, MD
- 2018 Jeep Wrangler JL
100% this. When the symptom occurs, stabilizer(s) may diminish the wobble, but the real problem is the steering box design is not very robust. Also the forces on the location where it is bolted in, the sway bar is also bolted in there so there is a significant amount of stress on that area. The procedure to tighten the bolts are also a bit fudgy, which may explain why some people have a better ride when they are tightened up.The stiff steering stabilizers are there to mask or shroud something that’s already not working properly.
You might ask what one of your aftermarket suppliers has to say. The top shelf mfrs will have degreed engineers who calculate the loads generated by their systems.
Good luck! You’ll figure it out.
