At the end of my rope of steering issues.***FIXED!****
rayzjeep
Ray
Melbourne, FL
2019 Jeep Wrangler Rubicon Unlimited
Aerospace Engineer
Any suggestions on the best vacuum pump/plug kit to buy?
Punknhed
Virginia
2023 Punkin Rubi XR
I have this one from Harbor Freight.
Jeep Wrangler JL At the end of my rope of steering issues.***FIXED!**** CCE1958E-F295-4ED0-9279-02148EC08116
where did you get the plug to go on the PS resevoir ? IM waiting on parts for mine, but, id like to get the plug enroute in case i wind up needing it, cant imagine its to pricey
Jeep&dogs
Jeep&dogs
Cedar Lake
2020 JLUr
Home Depot has a selection of them. It just needs to fit in the top of the reservoir when you pull the cap off. Drill a hole in it and the vac pump comes with a few barb fittings. Stick one in the hole you drilled and leave enough sticking out to attach a hose to. I think the plug was .99 cents or something like that.
Punknhed
Virginia
2023 Punkin Rubi XR
Pretty sure this was the one I picked up.
Jeep Wrangler JL At the end of my rope of steering issues.***FIXED!**** C691055B-7B9E-409D-94D0-6CFA6BDAD8A2
so drill a hole straight thru that, put it in the ps res. with the barb / hose connected to the vacuum ? just making sure i understand correctly. appreciate the help.
Jeep&dogs
Jeep&dogs
Cedar Lake
2020 JLUr
Fill the reservoir to max, but the plug in the res, connect one end of the hose to the barb you put in the plug and the other end of the hose to the canister that comes with the vac pump. Connect the other hose to the other side of the canister that’s marked “to pump” connect the other end of that hose to the vac pump. Pump the pump until the gauge reads 22” of vacuum. Leave it under vacuum for 5 minutes. Slowly release the vacuum and see if it pulls fluid in the system and the level in the reservoir drops. If it does fill it back up to max and repeat the process until it no longer drops the level in the reservoir.
Punknhed
Virginia
2023 Punkin Rubi XR
fantastic thank you
rayzjeep
Ray
Melbourne, FL
Aerospace Engineer
There's lots of youtube vids on how to do it...some start the vehicle and crank the wheel back and forth a few times while pulling vacuum.
Jeep&dogs
Jeep&dogs
Cedar Lake
2020 JLUr
I would not recommend that. You could actually damage the pump by doing that.
Jeep’n Jay
Jay
Salt Lake City
2018 JLU Sport
One more question, if I order the new cast iron box and replace it myself, will it work without getting the computer flashed? I read elsewhere you need a flash when changing the box out, not sure why that is, isn't this just a mechanical part?
Jeep&dogs
Jeep&dogs
Cedar Lake
2020 JLUr
No it will not, you need the programming to increase the pump pressure
TxJeepers
2022 JLUR XR
@Jeep&dogs
What’s the latest? Are you sticking with the replacement box fixed the shimmy? Do you think it had anything to do with your thoroughness during install?
After getting my steering box replaced by dealership through the TSB, I felt my shimmy improved (using my favorite trigger bump) but not gone. Just not sure replacing it with a third will be the end all.
Geekjeep
Gladiator sport s
I’m not saying it’s the issue. But I did go through more than one replacement box. So just food for thought. My first replacement had obvious issues. Second one was night and day
