At 65 MPH what RPM are you at?
viper88
Nick
IL
This a question for stock 8-speed automatic JLs only. No tire changes. On a flat highway doing 65 MPH what RPM are you at?
Please list 2.0 Turbo or 3.6?
Limited slip differential or not?
What model, Sport, Sport S, Rubicon, Sahara, Moab?
2-door or 4-door Unlimited?
What gear are you in?
stil2low
Craig
Ontario Canada
2015 Jeep jk
JLU sport s, limited slip with 3.6L
Just took this yesterday on my way home
alrola
Alex
Tampa, Fl
2019 Jeep Wrangler JLUR
Lift 2” and 35”
65= 2200
Matstock4
Santa Rosa, CA
2020 Jeep Gladiator Rubicon, 2018 Jeep Wrangler JLU, 2017 Toyota Sienna, 1989 Turbo Trans Am
Got the 6spd and I'm trying to figure out the point of shifting from 5th to 6th is... They seem to both be at a super low RPM.
Reedley Ca. USA
2018 Wrangler JL Sport
1,800 sounds about like mine as long as it’s flat or down hill. Any kind of a hill, even a freeway over crossing, my stock 3.6, 8 speed jumps to 2,200 or so.
Shenanigans
NorCal
JLU Rubi
Lift 2” and 35”
65= 2200
Manual or auto. What motor?
Seems awfully high. Either it’s not in its tallest gear or you’ve regeared.
rustyshakelford
Brett
Navasota, TX
2019 JLUR-8 speed 2020 F-350
If you put larger tires on it strogly consider gears at the same time if you want to keep drivabilty as close to stock or better
Brett
alrola
Alex
Tampa, Fl
3.6L auto.
It all depends.... wind behind me and top up then 1,900. It top open and against wind it sometimes stays in 7th for a while. I did not re gear as Ruincon has 410 and it falls witching it’s range.
I did get a non Rubicon 3.6L loaner and it was 1800 at 65mph
Sean L
Sean
North Carolina
Is this how all sport gauges are? My JLUR has a different layout
Thats what the instrument cluster looks like with the 5" Uconnect. A Sport S with the 7" Uconnect will have the upgraded instrument cluster that comes standard on the Sahara/MOAB/Rubicon.
MojoHanky
Wayne
Delaware
JLU V6 6M ($299 lease and driven like stolen), BMW 335D (400whp/600wtq)
Here's my JLU sport manual V6 at 65 in 6th. Pretty much right on 1,700 rpm. I wouldn't cruise in 6th at 65 as it's borderline lugging and would be hell on the clutch if you tried to stab it there. I ride in 5th mostly, and downshift to 4th for passing:
MojoHanky
Wayne
Delaware
6th is pretty much useless for anything beside the interstate at 70+ mph.
Jeepjunkie
Eric
Annapolis
2019 JLU Sport
Our 6 speeds have 2 overdrives, 5th is 0.81 and 6th is 0.72 (https://www.quadratec.com/c/blog/2018-jeep-wrangler-specifications ).
The old NSG370 had only one overdrive, 6th gear at 0.84 (http://www.novak-adapt.com/knowledge/transmissions/manual/nsg370).
So our 6 speeds have a really tall 6th gear. The sport 3.45 axle ratio is barely adequate with stock tires. I have 33” tires and plan on 35’s in the future. I plan to regear to 4.56’s (and add lockers, and get rid of the FAD, but that’s another story).
At 65 MpH I’m at about 1650 RPM, and definitely lugging the engine if accelerating.
I use 6th at 70+ speeds only.
Litfuse
Columbia, IL
2019 C7 Grand Sport, 2019 Ram 1500, 2017 Audi Q5.
Keep your RPMS above 2k, no matter what gear you are in. The motor doesn’t like to be below 2k rpms.
