- Aug 21, 2017
- North Salt Lake, Utah
- Website
- www.Artecindustries.com
- 2014 JKU, 2020 JLUR 2019 JTR 2021 JTRD
JL Steel Bumper Winch Plate
Your Price:$225.99 Use jlforums coupon code for 10% off
PREORDER - SHIPPING BEGINS 5/22
Part Number:JL5609
Did you buy a "winch ready" OEM steel bumper only to discover you can't mount a winch?
Do you have a SUPERWINCH EXP and can't find a winch plate for it?
Artec Industries is excited to announce our new JL Steel Bumper Winch Plate which gives you a mounting location for your winch in an OEM Steel Bumper. Our winch plate is constructed from robust 3/16" thick steel and engineered for maximum rigidity versus our competitors. Designed using State-of-the-Art 3D modeling with files directly from JEEP, WARN and SUPERWINCH for a precise fit requiring no modification of your jeep to fit most winches. These brackets are hard powdercoated black for direct bolt-on installation and a long life. All this at a PHENOMENAL PRICE and manufactured in-house which means it's MADE IN THE USA!
Features:
The only winch plate compatible with BOTH the WARN ZEON* and SUPERWINCH EXP
Thick 3/16" steel winch plate engineered better than competitors for ultimate strength and less weight
16 gauge aluminum front cover featuring stamped Artec A-blade logos
Allows you to easily preinstall winch on plate prior to installing bumper unlike competitors
Designed using original OEM 3D files from JEEP, WARN, and SUPERWINCH for maximum compatibility and best fitment. See APPLICATION GUIDE TAB for models tested.**
CNC laser cut and CNC bent in-house for precise fit
Includes hardware for mounting the front face plate
Includes thick washers for offsetting the bumper forward for any winches that may require it. Not needed for most winches.
Black Powdercoat for durability and direct bolt-in installation
MADE IN USA IN HOUSE
*NOTE: Previous Warn Zeon winches have a 180 deg turning clutch lever which interferes with the bumper but models bought around 3/2018 are shipping with a 90 deg version. Warn has a retrofit 90 degree clutch kit available...just call them.
Confirmed fitment winch models Physically Tested:
Warn Zeon series1
Superwinch EXP2
Confirmed fitment winch models virtually tested with 3D files directly from manufacturer:
Warn M8000
Superwinch Talon 95i (centered control box)
Superwinch Tigershark 95
Winch models that DO NOT FIT
Superwinch Talon 95 (with offset control box)
Warn Powerplant
Part Number:JL5609
Features:
Warn Zeon series1
Superwinch EXP2
Warn M8000
Warn Powerplant
