Artec Industries JL Belly Pans in Steel & Aluminum
roaniecowpony
Retired Engineer
The LOD mounts should go over the bellypan. Looks like they bolt in over the factory gas tank anyhow, so it should not be a big deal.
Will this skid plate system work with the Rock Slide Engineering stepsliders?
BBDOC
Victor
BMW 5-Series, Honda Civic, Honda Minivan
Second this question. I have RSE steps and want to make sure they will fit together.
Ski
Dale
Kansas
2019 Jeep JL Rubicon unlimited, 2009 Nissan Maxima
Did you ever receive a response from Artec as I have the exact same question?
Ski
Dale
Kansas
Did you ever receive a response from Artec as I have the same question?
roaniecowpony
Retired Engineer
I lost interest in the RSE powered step sliders after I found out they weigh over 200 lbs and up to almost 300 lbs if you get the armor. The remaining payload of my Jeep would be zippo after installing them, the skid plates and a bumper-winch setup.
DanW
Indiana
Can the Artec aluminum skid plates be painted or powder coated, or is that not a good idea?
ProjectJL
Joshua
Los Angeles
2019 JLU Rubicon
Yes. They can be painted or powder coated. I’ve seen them powder coated and that’s what I’m doing to mine once they arrive.
ProjectJL
Joshua
Los Angeles
2019 JLU Rubicon
They both fit on the 3.6 and I have no reason to believe it’s different on the 2.0. I have the RSE sliders with armor and a winch and steel rear bumper also. Artec aluminum is on order also.
You gain 200lbs net from the steps and about 100lbs net from the winch.
DanW
Indiana
Take a look at the Smittybilt XRC9500. It weighs only 46lbs with the synthetic rope. A little weight saved here and there adds up.
DanW
Indiana
Thanks!
TroyBoy
Troy
Vancouver Island, Canada
Yes but I cut bent and rewelded the lod mounting points. There are probably other ways to do it
gsxr310
CA
I’m running the Artec and RSE steps w NO issues. Some slight mods will have to be done if using a Long Arm Kit.
TxJeepers
2022 JLUR XR
They won’t rust and are underneath out of sight. Why paint?
