Artec Industries Inner Fenders for JL
Artec
Rock Sponsor (Level 1)
North Salt Lake, Utah
www.Artecindustries.com
2014 JKU, 2020 JLUR 2019 JTR 2021 JTRD
ARTEC JL Front Inner Fenders
PREORDER - Shipping begins 3/16
Freedom Edition, Vented, Solid desings All Avalaible to Pre Order
Run Larger Tires We tested with a 37x13.50x20 on a Stock JLUR !
Artec Industries is excited to announce our new JL Front Inner Fenders. These aluminum fenders not only protect your engine compartment from dirt and debris but do it in style. Our proprietary process of stamping our logo not only adds an additional element of style not seen in the industry but also increases the rigidity of the whole inner fender. In addition, the laser cut vents keep your engine compartment cool and don't require you to bolt on an extra piece of mesh material. All this at a PHENOMENAL PRICE and manufactured in-house which means its MADE IN THE USA!
Features:
Allows use of larger tires...tested with no lift and 37" tires with no rubbing
Proprietary A-blade stamping process for increased rigidity and mackdaddy status
Lightweight 1/16" Aluminum construction
CNC laser cut and CNC bent for precise fit
Can easily be trimmed for use with coilovers or bumpstops without ruining the vented area (or see No-Cutout Versions)
Compatible with Trimmed OEM fenders
Laser cut venting means no extra pieces of material to bolt on
Two main piece construction for lower cost of shipping
Pressed PEM nuts on seam between pieces for easy installation
Covers gap between outer body sheetmetal and inner body sheetmetal
Extra bottom flange directly behind wheel prevents grime from getting inside the gaps in the undercarriage sheetmetal
Price is per pair - Includes Passenger and Driver side inner fenders
Shipped bare unfinished aluminum for decreased cost and ability for you to paint or powdercoat to fit your style**
NOTE: While all precautions are made to ensure the aluminum surface is protected, small scratches from either the raw material from the factory, the manufacturing process, or the shipping process may be present in this UNFINISHED product. We recommend you finish this product with either painting, powdercoating or another similar process and prepare the surface prior to finishing as you would normally to remove any minor blemishes.
AZCrawl
AZ
2018 Granite Jeep JLUR
Are rear inner fenders next?
Artec
Artec
Tech Tim
Summit Sponsor (Level 3)
Tim
Poulsbo, WA
4x4 of all kinds
Looks awesome!
Dreadnought_Leviathan
Robert
Dallas, Texas
Finance
Bought a pair from Northridge. When will the rear fenders be available?
mnrafter
Patrick
Bayport, MN
www.mcneils.com
2018 Jeep JLU Rubicon, 2013 Jeep JKU Rubicon, 2015 Jeep Grand Cherokee Summit
Special Procedures Radiologic Technologist
Features:
Are these plug and play.....easy install?
Yellow109r
2018 Jeep Rubicon JLUR, Bright White
Aircraft Industrial Engineer for the DoD
any word on rears?
Artec
Artec
mwilk012
2018 Ocean Blue JLU Rubicon
Service
Would there be any issues with leaving the metal raw and unfinished? As aluminum I can't imagine it's going to corrode much.
Artec
Artec
It will eventually corrode but it will take some time for that to happen
Drawls
Josh
Oregon
Water distribution
I understand branding/marketing but man those logos are just huge. Any way to get a version that are clean or a much smaller logo?
I personally like the logo but, the reason for a larger logo is to put added air to help cool the engine.
Artec
Artec
