JL (2DR) Artec Industries 2 Door JL Bellypans Now Available !
Artec
Rock Sponsor (Level 1)
North Salt Lake, Utah
www.Artecindustries.com
2014 JKU, 2020 JLUR 2019 JTR 2021 JTRD
THE WAIT IS FINALLY OVER THE LONG ANTICIPATED 2DR BELLYPANS ARE FINALLY IN PRODUCTION AND READY FOR PURCHASE THESE ALUMINUM SKID PLATES OFFER HEAVY DUTY YET LIGHTWEIGHT PROTECTION FOR 3.6L AND 2.0L TURBO POWERED JL'S .
Artec Industries' NEW JL Bellypan is designed to give your 2018+ Jeep JLU Wrangler full protection underneath the vehicle. Designed using CAD files directly from the manufacturer and high quality 3D scans, this belly pan skid plate ensures that you have a great fit with factory components. Made from 1/4" thick 6061 Aluminum and 3/16" zinc plated steel, and CNC cut and formed, the Artec JL Bellypan Kit offers both a strong and lightweight solution for your new Jeep JL.
Jeep Wrangler JL Artec Industries  2 Door JL  Bellypans Now Available ! 1667856740831
Jeep Wrangler JL Artec Industries  2 Door JL  Bellypans Now Available ! 1667856749259
Jeep Wrangler JL Artec Industries  2 Door JL  Bellypans Now Available ! 1667856769712
Jeep Wrangler JL Artec Industries  2 Door JL  Bellypans Now Available ! 1667856774970
  • Specifically designed for the 2 door JL...not a hacked up 4 door version.
  • Available for 2018-2020 and 2021+ model years (choose in options).
  • Increases ground clearance of 3/4" from factory skids and even more compared to other aftermarket skid plates
  • 1/4" 6061 Aluminum for skid plates, 3/16" zinc plated steel brackets
  • Designed from factory CAD files for great and ultra precise fit.
  • CNC laser cut and CNC formed using custom rolled dies for high strength, unique look, and perfect contour fitment to OEM components.
  • All bolts under skid plate are countersunk for absolutely smooth bottom
  • All nuts are pressed into steel brackets for easy, one tool removal
  • Bolts directly to OEM T-case crossmember and frame using heavy duty flat head bolts that match OEM thread
  • No need for an aftermarket T-case crossmember for completely flat surface
  • Modular design lets you take off only one section for vehicle servicing
  • Protects Oil Pan, Transmission Pan, Gas Tank, Front Exhaust and Transfer Case
  • OEM gas tank skid is replaced for reduced weight and 3/4" higher clearance*
  • Artec Gas tank skid can be removed without dropping entire tank thanks to additional tank strap.
  • Clearance near rear drive yoke shaft to prevent rubbing
