Artec Industries 2.0L Turbo Bellypan Skid Plates
Artec
Rock Sponsor (Level 1)
North Salt Lake, Utah
www.Artecindustries.com
2014 JKU, 2020 JLUR 2019 JTR 2021 JTRD
ALUMINUM SKID PLATES FOR HEAVY DUTY YET LIGHTWEIGHT PROTECTION.
At a total of 91 lbs, the total net weight is only 15 lbs more than factory skids but much heavier duty and more complete coverage.
Artec Industries' NEW JL Bellypan is designed to give your 2018+ Jeep JLU Wrangler 2.0L Turbo full protection underneath the vehicle. Designed using CAD files directly from the manufacturer, this belly pan skid plate ensures that you have a great fit with factory components. Made from 1/4" thick 6061 Aluminum and 3/16" zinc plated Steel, and CNC cut and formed, the Artec JL Bellypan Kit offers both a strong and lightweight solution for your new Jeep JL.
Adds only 15 lbs to net weight of vehicle yet covers far more and is heavier duty than factory skids
91 lbs total weight compared to the Steel version at 163 lbs...a 44% weight savings
Increases ground clearance of 3/4" from factory skids and even more compared to other aftermarket skid plates
1/4" 6061 Aluminum for skid plates, 3/16" zinc plated steel brackets
Includes 1/4" thick Aluminum skid plate for 48 volt E-Torque battery system
Designed from factory CAD files for great and ultra precise fit.
CNC laser cut and CNC formed using custom rolled dies for high strength, unique look, and perfect contour fitment to OEM components.
All bolts under skid plate are countersunk for absolutely smooth bottom
All nuts are pressed into steel brackets for easy, one tool removal
Bolts directly to OEM T-case crossmember and frame using heavy duty flat head bolts that match OEM thread
No need for an aftermarket T-case crossmember for completely flat surface
Modular design lets you take off only one section for vehicle servicing
Protects Oil Pan, Transmission Pan, Gas Tank, Front Exhaust, Transfer Case, E-Torque Battery
OEM gas tank skid is replaced for reduced weight and 3/4" higher clearance*
Artec Gas tank skid can be removed without dropping entire tank thanks to new additional cross-member and tank strap.
Clearance near rear drive yoke shaft to prevent rubbing
*OEM gas tank skid removal required. For easiest install, remove skid when tank is near empty. See instructions for simple ideas on removing OEM gas tank skid.
On sale$1,799.99
PREORDER - Shipments begin June 28th
Part Number:JL4102
OffroadTreks
Boise, Idaho
2018 Jeep JLU 2.0TE
Love the product, but wish there was the option to buy just the engine/trans section for now. Can't see the need for an entire system at this stage in the game. I'm not likely running Prichett tomorrow. But plenty of opportunities to nail that engine pan.
zshowket
Ziyad
Northern Ca
2019 JLU Wrangler & 2008 Rubicon 2 Door
i agree, would love to just get engine/trans section as well. Any options for us you think?
Ski
Dale
Kansas
2019 Jeep JL Rubicon unlimited, 2009 Nissan Maxima
Hey Artec, I am looking to possibly purchase your belly pan skid plate system on my 2019 JL with the 3.6 engine. However, I am having Rock Slide Engineering's Step/Sliders installed on my Jeep and need to know if your skid plate system will work with these installed. Please let me now as soon as possible so I can determine how to proceed. Thanks for your time!
Ski
AgentTML
Tri
CA
JL Rubicon (2018), Honda Pilot Touring (2010), Ford C-Max SEL (2013)
Add me to the count for those who desires a 2-Door product.
OnlyOne
Northwestern New Mexico
2021 Sport S Diesel on 37s
Yes. Please add the 2 door.
2Wheel-Lee
Lee
Orange County, CA
2020 JLUR, 2006 Dodge Ram 2500 CTD, 1986 Suzuki Samurai, 1975 Datsun 620
Do you know if this will be the similar to the 2020 2.0 without e-torque in the Rubicon? I'm guessing it would cost less since there's no high-voltage battery guard?
ChattVol
Tennessee
JLU 4 door
On sale$1,799.99
Part Number:JL4102
Looks good... wish there was the option to buy just the engine/trans section for now. Can't see the need for an entire system.
OnlyOne
Where’s the 2 door turbo versions?
ProjectJL
Joshua
Los Angeles
2019 JLU Rubicon
Ski
Yes, they fit. Also on the 2.0.
