GMONEY
- Greg
- Sep 24, 2022
- Temecula California
- 23 2D Rubi Earl
Yeah at this point I'm guessing we don't get a full set for the 2 door
Hey guys, No Jeep platform that we have announced development for will be removed. JL 2door engineering data is designed.
As I mentioned in the JLU cargo thread we are in tool shop limbo. When I get confirmation that the tool shop we hire to cut the tools starts loading the cnc, that is when I announce presales. It is only at this point that I can make any type of guarantee for timing. Tools are made in states so we don't have that variable to worry about at least.
As soon as I have a date I can stand behind I will announce it from the mountain tops.
Was it hard to install the front pieces for the two door?I have the Front set for my 2 door JL. Outstanding product. I absolutely cannot wait for the full set.
put me at the top of the list Armorlite!!!!!
Not at all. There is a YouTube video if you are worried about popping the console up or the rocker panels. Armorlite fits perfectly as if it were a factory product.Was it hard to install the front pieces for the two door?
Probably better to just remove the carpet and put in bedliner no?While I'm waiting, I wonder if coating the carpet with a bedliner, slightly reduced to penetrate to the base would work. Leave the carpet in, mask and work in Bedliner with a roller and brush for the edges. After it cures, it should be water proof, nubby texture, easy to clean.
Nothing to lose at this point
I removed the carpet and put in bed liner. If you want suggestions or pic’s. I have both.While I'm waiting, I wonder if coating the carpet with a bedliner, slightly reduced to penetrate to the base would work. Leave the carpet in, mask and work in Bedliner with a roller and brush for the edges. After it cures, it should be water proof, nubby texture, easy to clean.
That's an interesting idea. Grab an old floor mat and test it out first. If your idea actually works, then do all the carpet. Let us know either way. You just may start a trend!While I'm waiting, I wonder if coating the carpet with a bedliner, slightly reduced to penetrate to the base would work. Leave the carpet in, mask and work in Bedliner with a roller and brush for the edges. After it cures, it should be water proof, nubby texture, easy to clean.
