mattshotcha
Lexington, KY
www.guninteractive.com
2021 Jeep Wrangler Willys JLU
Lead Community Developer - Gun Interactive
I just installed mine in my 2021 JLU, but stopped short of finishing the front seat trim due to the season and darkness. I was really psyched for this product, as I hate carpeting, wheel in a lot of Kentucky mud that seems hell bent on sticking around, and have a 5 year old daughter who thinks Goldfish are confetti.
After install, I am more than happy with the product. The quality exceeds my expectations by far. I have yet to get them grimy of course, but there's a quality bar you know when even handling the product or installing that let's you know it was a good purchase. Armorlite has that in spades.
Now a couple tips for intrepid installers of the Armorlite product in a JLU.
  • Wear gloves, I should have. They said to wear gloves, I didn't listen, I got cut on the seat tracks.
  • If you have trouble lining up the drains, and tried the methods in the Armorlite video, try lifting the edges of the flooring section some while holding the middle down to the sheet metal, lining up the drain, popping that bad boy in FULLY, then press the edges back down. I had this up front on both sides and the method I mention was all that would work.
  • I did this in chilly weather here in Kentucky. I don't recommend it. At least get into a garage at a buddy's or something. Fighting with the sill on the passenger side and the thing snapped with much less force than I've used on various other interior panels, probably from the chilly weather. If you did too, don't panic. It's a $50 mistake.
  • The JL has strange random wires dangling in the foot well on the passenger side. You didn't rip these loose, they're from options you don't have. Don't panic. Check the wire end for a sealed heatshrink and you'll know it was an optional wire.
  • The seat bolts have a little red Loctite on them from the factory. Not enough to be an issue, but enough to need some force if you're in the cold like I was. Maybe consider a hair dryer or heat gun on them for a sec to make shorter work of them.
  • The JL interior panels you'll be removing line up with each other like crap (Not an issue with the Armorlite, an issue with plastic to plastic panel seams). They line up like crap from the factory, so maybe take some mental notes on fitment of these panels before you rip them off since if you're like me you'll be looking at the wonky plastic in the JL thinking "Was that always that way? Should I whack it again?"
That's all I could think of to add here to the notes on install. I really appreciate the link to the carpet clips, going to order some of them as well. Love this product already, will stop back in to post a pic or two tomorrow after I finish reinstalling the plastic up front. And I'm sold on the rear cargo area as soon as it launches. I don't mind waiting for a product of this quality.
@Armorlite Kail I don't recall getting a discount code for the cargo area when I ordered my front and rear JL set the other day. Is that still a thing or no?
EDIT: I did have one further question for Kail, does the front floor go on top of the rear floor where they meet under the seat or does the rear go over the front? The shape of the floor in that area looks like the rear goes over the front, but I wanted to double check.
Armorlite Kail
Armorlite Kail
Peak Sponsor (Level 2)
Kail
Texas, North Carolina, Michigan
JLU Rubicon, JKU Rubicon, 64 C10, 61 Panhead
Glorified Floor Salesman
We will send you an email when the JL cargo kit comes out and give you a chance to get in early. Still no date on this though sorry, our engineers are working hard as they can on everything.
Yes the rear floor does go on top of the back edge of the fronts, it has a step to it to overlap that.
Also note that the rear parts that are under the back seat go under the back cargo carpet, this way if anything rolls down it doesn't go under the Armorlite.
Armorlite Kail
Armorlite Kail
Kail
How to access the load floor compartment in a 2-door JK? From the pictures on the website, it looks as if the sides of the rear mat would tuck in under the side panels and/or wheel well covers?
No it will be accessible as normal.
pnut
Michigan
2021 Wrangler 392 35's, and 2015 JKU 35s (wife's)
Armorlite team - just following up on the status of the rear cargo area system that would replaced the carpet in a 4 door?
I looked on your website didn't see it yet and just about to order my next 392 where I would put it into.
Thank you in advance.
mygreenkaw
Indiana
2020 JLU Rubicon
The rear cargo area promo good for anyone that purchased the front and rear already? I'm in for the cargo area when it's ready!
+1 here I love this floor, easy to clean as well just sweep out with vacuum, spray with your choice of cleaner (Mopar Total Care or like), then wipe clean! Looks like new.
JKS Manufacturing
