Are these the correct TPMS sensors for my stock 2021 Rubicon wheels?
Goin2drt
Kentucky (formerly Peoples Republik of Kalifornia)
18 Rubicon, 17 Grand Cherokee Trailhawk
Those will not be.
1) Those will be refurbished and not OE sensors. Could also be used.
2) Those will also not have the TFA (Tire Fill Alert) capability.
You will not get an OE set or even a set that will work for that price. Lots of fakes and refurbished TPMS out there. I new quality set that will allow you to continue with the TFA will need to be a Schrader 29093 and they are on national backorder not expected until the end of this month.
If you do not care about TFA then you can use Schrader 20398 and those will also not be that cheap. $170 for a set of 5 or so will be the going rate. You can also use Schrader 33500 and have them programmed for your vehicle but those will be around the same price.
Hope that helps.
PJJPtx
PJJPtx
Jason
Dallas, TX
'21 392, '21 JLUR, '18 Sahara, Viper TT, Gallardo
  • Thread starter
  • Thread Starter
  • #3
Those will not be.
Hope that helps.
WOW! Thank you for the detailed info. I went ahead and ordered Schaffer 29093 from the Amazon link based on your info. Thank you.
Goin2drt
Just make sure they are actually 29093. Many listings are for 29093 but you will get another sensor that works but will not have Tire Fill Alert. Schrader marks all there TPMS with a sticker like this or similar. I am going to make you a friendly wager they will not be 29093's. They are on national backorder and have been on back order for a while. The system is out of them.
Wolfy
SLC & Ivins Utah
2020 Jeep Wrangler Sport S
So they are 29093 and the sticker has that nowhere on it. That makes it easy to identify. :facepalm:
Goin2drt
It was an example. If you read the posts you would have read that they are out so pretty hard to show a pic of actual sensor when on National back order.
PJJPtx
PJJPtx
Jason
Dallas, TX
  • Thread starter
  • Thread Starter
  • #9
Here’s what they sent me. Does this look correct?
Gregj
Greg
West Texas
JT Overland North Edition, JlU Rubicon, JLU Sport, upgrades in progress!
On a related question, I replaced the radio in my Sport with unit out of a '21 Rubi and when I first powered it up it had the icon for TFA, I wonder if I get these TPMS and see if JScan can enable it, would it work?
moments.by.ron
Ron
Macedonia, Ohio
2021 JLU Sahara 4xe
Are they apparently still on national backorder? Can't find 29093's anywhere.
Superchips Flashcal Programmer out for JL Wrangler
