- Mike
- Aug 16, 2022
- Severance, CO
- '22 JLUR, '23 Donkey because gas is too expensive
- Banned
I've got a '22 JLUR with the 2.0. The dealer says all these are normal:
1) Performance limited Service Fuel System - I've looked around and found this seems to be an issue that Jeep doesn't know how to fix. Dealer is telling me this is "normal"
2) Steering wheel crooked. Jeep tracks straight but the steering wheel is off after the dealer replaced a sway bar. Dealer is saying this is "normal".
3) A vibration in the steering wheel between 63-70mph. Dealer is saying this is "normal". This also started after the dealer did work.
4) Some rubbing noise that started after the dealer did some work. Sounds like maybe something with the brakes as when I press the brakes, it gets slightly louder. Dealer is saying this is "normal".
5) Proximity door locks do not work for about 5 seconds after exiting the vehicle. I stop, get out, close the door, press the button and they won't lock for about 5 seconds.
6) When in 4Lo, the automatic transmission shifts really rough. When I shift from 1 to 2 or 2 to 3 or 3 to 4, it's very jerky, like someone who is driving a manual transmission for the first time. I also seem to hear some sort of clicking. I would describe it as two gears that are loose and bouncing back and forth between the teeth.
Any thoughts on this?
