The only reason my part numbers were visible were because they failed to install either of them. So when the new dealership we’re re-torquing my kit and found the issue, I went into my garage and pull those directly from the Mopar box.I can't see the part numbers anymore with it installed.... I literally had to threaten lawyers and stand over the tech while he did the 3rd install to get it lined up properly per the instructions.
My (ex) dealer said they installed the new ones but I found a factory grey pen match mark on my factory spring and the installed isolator post lift install... it was just one lie after another.Mine were black and ended in AC. I was told they were the 3rd generation Mopar lifts to come out. April 2019 marked on the crate. There was still a bow on the driver's side front spring. I ordered the RK pads from @Northridge4x4 with their forum discount. (@$24 for the pair) I'll let you know if they straighten out.
FYI. I installed my Mopar lift so I am sure the new ones (AC) were black.My (ex) dealer said they installed the new ones but I found a factory grey pen match mark on my factory spring and the installed isolator post lift install... it was just one lie after another.
Do you happen to know the full part numbers or have the instructions with them?Mine were black and ended in AC. I was told they were the 3rd generation Mopar lifts to come out. April 2019 marked on the crate. There was still a bow on the driver's side front spring. I ordered the RK pads from @Northridge4x4 with their forum discount. (@$24 for the pair) I'll let you know if they straighten out.
Let me know which part you need the numbers on and I will try to take a pic. I'm sure I have the instructions also.Do you happen to know the full part numbers or have the instructions with them?
I may just go with RK and skip the confusion lol.
Supposedly the driver side front coil is supposed to curve.
For the spring pad isolators.Let me know which part you need the numbers on and I will try to take a pic. I'm sure I have the instructions also.
My apologies. I couldn't find my instructions manual.For the spring pad isolators.
No problem. I tend to lose instructions then find them years later crumpled up somewhere. Lol.My apologies. I couldn't find my instructions manual.
I'll try to take a pic tomorrow of the actual perches. Attached is the parts list for the "AB" version second generation Mopar lift kit. Hopefully the AB converts to an AC on the 3rd generation parts list. Either way, I'll look for my manual and take pics for you tomorrow.
Thanks for the info. Both springs turned out semi straight? Does the thin part facing forward cause the spring to seat oddly?I have the rk isolators on for a few months now. Definitely the way to go. They’re not side specific like the Mopar ones, but not a big deal. The thin part of the isolator faces forward on drivers side, so the spring is turned 180 degrees. Mine collapsed on me wheeling.
That looks pretty good. Not much bow at all. Think I'll go that rought.It straightened springs out significantly, and no issues with spring turned the other way. I thought there would be when I first put them on because I thought the bow would be bowing in instead of out. You can still see a slight curve but nothing like with original perches. Here’s drivers side.
Which isolators collapsed?I have the rk isolators on for a few months now. Definitely the way to go. They’re not side specific like the Mopar ones, but not a big deal. The thin part of the isolator faces forward on drivers side, so the spring is turned 180 degrees. Mine collapsed on me wheeling.
