Are there any security cargo covers that truly work with soft top down?
Trav.city
Rich
Michigan
2018 Wrangler Unlimited JL Rubicon
Sales Manager
Hello, I love how the Jeep Backbone security cargo carrier fits and that it is aluminum. Although for the soft top version, I wish it actually dipped down to accommodate the soft top in the down position, then maybe add a piano hinge to open the back up 12” or so. In my opinion, when the soft top is down is when your cargo area is most vulnerable and the only reason I want one. I emailed Jeep backbone to please send a picture with the soft top down and they have yet to send it.
Back to the title, Does anyone know of any hard security cargo box that actually works well with a soft top down?
Thanks in advance for your help.
Shots
Winchell
Ohio
'22 Rubicon
I made my own enclosure. It's the only way to truly get the features you want. I made my prototype out of wood, and upholstered it in carpet. One of these days I'll make an updated version out of aluminum. I made wood first because it's cheap and I can easily make modifications as I use it and figure out what works, what doesn't and/or what would make it better.
I'd recommend making your own so you can put that hinge in where you want it, and make sure it works well with the soft top down. Otherwise there are only 2 or 3 and they all seem very similar.
Trav.city
Trav.city
Rich
Michigan
Sales Manager
Thanks for the idea. I think I will give that a try. What did you use. 1/2 plywood. Any pictures of yours?
Shots
Winchell
Ohio
'22 Rubicon
Yes, I used 1/2" plywood. I made a tread on the build → link
It only cost a fraction of the commercially available units at roughly $100. I have a few ideas for the aluminum 2.0 version, but that's the point in making it from a cheap workable material first.
One idea being to make the top panels hinge, but to do so the rear panel has to be just a bit shorter than the front one. I need it like that because I want to be able to hinge it flat open without hitting the seat back.
The other idea is to integrate some sort of tie downs or slots to allow for easily securing items to the top of the box.
Until then, here's a set of photos. Good luck with yours, and happy building. Make sure to post it so I can pirate any ideas you may have that I like. ;)
Trav.city
Trav.city
Rich
Michigan
Sales Manager
Thanks again for the idea and pictures. I will be trying to build something.
Digger70
Pennsylvania
2021 Jeep Wrangler Unlimited Willys
I had the Tuffy security enclosure for my JK and used it for 4 years. I used it during the warm months when I had my bikini top on and the cargo cover fit over it. I had the backseat out in my JK since I never had more than one passenger. The back panel was easy to remove if I had something big to put in the back. Here's the version for the JL https://www.quadratec.com/p/tuffy/security-deck-enclosure-jeep-wrangler-jl-4-door I'll probably get it when there's more soft top/bikini top options. I wish I was mechanically inclined like Shots and would build my own.
Trav.city
Trav.city
Rich
Michigan
Sales Manager
Thanks, the problem with that is the JL soft top drops down into the tub about 4”s and none of the current first to the market brands have engineered it to accommodate that. I will probably build my own.
WUFJeep
Portland, OR
2024 Jeep Wrangler JL Willys 2 Door
Same, couldn't find anything I reeeeally liked. But I also have the 2 door puzzle to solve. Shots' is super profess! Mine is a little more down and dirty 2x4 style but here's the link in my profile:
https://www.jlwranglerforums.com/fo...eping-and-storage-platform.30368/#post-705018
Trav.city
Trav.city
Rich
Michigan
Sales Manager
Shots
Winchell
Ohio
'22 Rubicon
Paramaniac413
York,PA
2018 Wrangler JL Sahara
You could look at the Slipstream from Diabolical. I run a hardtop but the instructions reference soft top support. It’s pretty solid.
I have the Slipstream as well, but I run a soft top. Be prepared to have to strap down your soft top if you get one and the top doesn’t sit down the whole way, so the lock doesn’t work. I strap mine down with Velcro around the bar for the back window. I also use two straps around cargo hooks attached to the hard top screws I’ve got. I love my Slipstream, but just didn’t want you to be surprised if you get one.
Sital
Rich
Massachusetts
2023 JL Willys - Reign
To second the above post, the soft top will not lock with the Slipstream. A bit pricey, but Diabolical also sells a soft top cover (photo from Diabolical). It compacts the soft top down just a little bit, but mainly it keeps the soft top from bouncing or moving while driving...and it does this very well. Also, it makes the top look nicer when looking at it in the rear view mirror.
ocrejects
Orange County, CA
2021 Rubicon, 2018 JLU Rubicon, 2018 Tiguan SE
Diabolical Inc. I’ve had this for over a year 100% security
Trav.city
Trav.city
Rich
Michigan
Sales Manager
Thanks for the confirmation of what I thought. That is exactly what I would like to avoid.
