Deleted member 61263
Guest
Brand New in original box. Would prefer to sell local. $900. But will work with price
- Ultra compact twin motor, dual cylinder design makes this the high flowing portable compressor of its size on the market at 6.16 CFM (no load) and 4.65 CFM (at 29 PSI)
- Integrated aluminum air tank and pressure switch regulates pressure between 135 PSI and 150 PSI which is suited to most air powered tools
- Mounted in a waterproof carry case constructed from a durable impact resistant polymer; the carry case has convenient compartments for storing the air hose and other compressor accessories
- Ducted IP55 sealed brushed DC cooling fan and anodized aluminum motor mounting brackets effectively dissipate heat from the motors, heads and electronics allowing for a 100 percent duty cycle (under room temperature conditions)
- Kit includes: Water proof case, twin compressor, air tank, canvas organizer, 20 feet air hose, inflator and blow gun
